Cletrac F Crawler Project
this thread has 10 replies and has been viewed 2967 times
Old 10-11-2013, 10:11:48 PM
ttyR2 ttyR2 is offline
Default Cletrac F Crawler Project
The Branch 15 club in Salem, OR has a well-loved Cletrac F that I adopted for the winter to put it back in running condition. I will post some pictures later.
The track rollers ride on links and the rollers seem to have about 1/8" play in them (maybe a bit more) and I was told that this specific machine likes to throw a track when turning, but I don't know which one. I'm curious if the undercarriage is just worn out and that's what the issue is. One of the tracks is currently very loose and needs to be tensioned, so it could be as simple as that.
The Following 2 Users Say Thank You to ttyR2 For This Post:
Old 10-12-2013, 12:38:40 AM
19-65Port 19-65Port is offline
Default Re: Cletrac F Crawler Project
It's as simple as that the play in the rollers is normal.
Old 10-12-2013, 11:28:27 AM
Bud Tierney Bud Tierney is online now
For all things Cletrac--advice, parts, sympathy, as circumstances require--Landis Zimmerman at olivercletrac.org/com/net (one of those!)...Good luck.
The Following User Says Thank You to Bud Tierney For This Post:
Old 10-13-2013, 05:25:59 PM
A little update. Checked all the plug wires with a DVM and all of them were over 6k ohm resistance even though they are solid core. The wires were also more than a foot longer than necessary, so I cut them down to good wire and soldered the brass ends back on. They measure 2~5 ohms now. Good enough to start the engine until I buy new wires.
The inside of the magneto looked pretty good other than white corrosion on the points. Cleaned them up with fine sandpaper and started getting good spark.
It coughed a few times on ether. I figured the carb was totally gunked up but hooked up a temporary gas tank anyway. No dice. Pulled the carb down and the bottom was full of dried "honey", sticky stuff. Disassembled and in to the carb cleaner tank for a few days. Hopefully the floats are still intact.
I'm looking for a couple good high quality pictures of the top of the engine, specifically the governor setup and throttle rods. From the looks of it, someone bodged this setup together and cut/welded the governor linkage.
I'm also looking for a good PDF copy of the owners/service manual.
Old 10-13-2013, 05:45:20 PM
Give me a couple days a can copy a manual and post some pics There's 3 F's here. A narrow gauge and a couple standard gauges.
The Following 2 Users Say Thank You to David Hoover For This Post:
Old 10-19-2013, 07:54:42 PM
Had a little success after cleaning the carb out. I was able to get it to fire for a moment but then die. After a lot of cranking, it finally lit off and ran well. I ran it for a minute then shut it off because it didn't have any water in it. It flooded easily when I tried to start it again.
According to what little info I can find, the engine should have come with a Tillotson CD1A carburetor and Eisemann GS4 magneto. It actually has a Tillotson DY9B carb and Wico Model X spec XH-184 magneto. I would like to track down a good used CD1A carb if any of you happen to have one.
I'm still looking for some good clear pictures of the top of the engine, specifically showing routing of the governor linkage.
Old 10-19-2013, 11:36:15 PM
Kurt Kocher Kurt Kocher is offline
We are going to be doing one this winter. Looking forward to seeing your progress I would also be interested in some information on this model. Thanks!
Old 10-20-2013, 02:06:23 PM
Oilpulled Oilpulled is online now
Don't worry about 5 ohms resistance in the wires. Some of that may be your meter leads. You have 10,000 to 20,000 volts and maybe .01 ampere maximum which would only drop one volt if you had 100 ohms wire resistance. If there is corrosion causing the resistance, then that could cause future problems. The insulation on those old high tension wires would be the major concern. Sparks will jump right through poor or cracked insulation.
The Following User Says Thank You to Oilpulled For This Post:
Old 10-20-2013, 07:28:40 PM
heres a scan of the manual.
ID:	177531   Click image for larger version
ID:	177532   Click image for larger version
The Following User Says Thank You to David Hoover For This Post:
Old 10-20-2013, 07:31:07 PM
more manual
ID:	177534   Click image for larger version
ID:	177535   Click image for larger version
ID:	177536   Click image for larger version
Cletrac HG 68 d21smith Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 09-09-2017 12:29:35 PM
Cletrac Oliver Crawler Dozer Nevr-Enuf-Stuf Dozers and Crawlers 4 12-18-2012 10:19:49 AM
Cletrac EG Project Adam Hartz Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 10-11-2012 12:50:07 PM
Cletrac Crawler w/ ford eng and hood. rails Antique Farm Tractors 5 04-26-2011 06:44:49 PM
Info on Oliver Cletrac crawler 1907Waterloo Antique Farm Tractors 6 12-29-2008 11:40:38 AM
