Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles
Farm + Industrial Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers, pumps and antiquities of the industrial revolution.
Steel Wheeled Wagon Cast Iron Hub Removal
this thread has 10 replies and has been viewed 766 times
Old 09-24-2018, 12:38:10 PM
Outbackrider Outbackrider is offline
Default Re: Steel Wheeled Wagon Cast Iron Hub Removal
Thanks for the responses. With the Oxy/Acetylene torch, I was able to get all hubs removed. All 4 hubs were normal right hand thread.
I plan to clean up the axles and get this unit operational again.
I'm missing a couple of grease cups, I plan to get those replaced.
The frame had JD green paint on it in tucked away under the axle area and the wheels and spokes had some JD yellow paint remnants...I couldn't find any other casting marks, but I'm thinking at one time, this was put together with JD parts.
The Following User Says Thank You to Outbackrider For This Post:
IHC steel wheeled wagon JHuggans Farm + Industrial Antiques and Collectibles 0 01-19-2013 08:09:04 PM
Cast Iron vs. Steel Tim Christoff Antique Gas Engine Discussion 9 01-24-2011 11:06:15 AM
Steel wheeled wagon JIMnWV Horse Drawn Equipment 2 09-30-2010 08:09:00 PM
To make new valves - cast steel / cast iron Edwin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 05-02-2009 12:53:18 AM
Cast iron vs. steel valves Chris Kirk Antique Engine Archives 1 10-09-2003 11:04:45 PM
