Steam Engines
Boiler Fabrication
this thread has 460 replies and has been viewed 114601 times
Old 11-10-2005, 11:09:30 AM
Dan Donaldson's Avatar
Dan Donaldson Dan Donaldson is offline
Default Re: Boiler Fabrication
Originally Posted by Pennerjw
That will be very interesting! I am curious if you could guesstimate the cost, were I to walk into your shop with a handful of blue-prints and say, "Build me one please!".
We do estimates for all work that customers bring to us. I did not do an estimate before starting this project because I knew most of the work would be done by me. I knew ahead of time how much material was going to cost me. By using the "real time" sheets that I have been keeping on this job I will be able to estimate the cost of future boilers projects. If I take on another boiler project.
Dan
Old 11-10-2005, 02:10:40 PM
AndyG's Avatar
AndyG AndyG is offline
Images: 7
Originally Posted by Dan Donaldson
I'm shooting for February. I'm just not sure which year though.
Dan
I love that statement Dan! I suspect that anyone who has restored a steamer can relate. I know that I didn't expect the Huber to still be a pile of parts 2 years after coming home! I better get busy if I want to build a fire this spring.
Old 11-13-2005, 01:52:11 PM
LundMachineWorks LundMachineWorks is offline
Dan, I have a 30 H.P. that I am working on right now. Does you boiler have the stay bolts on the front tube sheet right next to the handhole?
I also cut the main steam line off because it is going to be replaced. It appears to be caulked into the sheet, or thread in just through the sheet, and a slip fit into a dry pipe that goes into the steam dome.
Old 11-16-2005, 12:58:18 PM
My boiler does not have stay bolts next to the handhole on the front tube sheet.
I assumed that the main steam line was threaded through the front tube sheet and threaded into a coupling just behind the front tube sheet. The coupling joins the steam line that extends through the tube sheet to the steam line inside the boiler that extends back to an elbow that attaches to the pipe that goes up into the steam dome. If you get into your boiler and find something different I sure would like to know how it is arranged. I see the engine listed on your web site but there are not any pictures yet. I'm looking forward to seeing the pictures.
Dan Donaldson
Old 11-16-2005, 01:12:09 PM
Jeff,
I see the pictures are there now. Are you planning to take out the top row of tubes? If you do would it be possible for you to get a picture from behind the front tube sheet looking up at the steam pipe?
Dan
Old 11-16-2005, 01:30:11 PM
Jeff,
Who owns the 30 HP A. D. Vance?
Dan
Old 11-16-2005, 02:31:10 PM
Dan, I am planning to take picture from the inside this afternoon, and post them on my website tonight. Kevin and Denis Schirmers of Sauk Center Minnnesota own this engine. Apparently it came from Rollag about 30 years ago. The gearing and other mechanical items are really great. The inside of the boiler is really scaled up. Between the throat sheet and firebox was filled level with scale. There were also two squirrels that were evicted. Sorry PETA.
Old 11-18-2005, 03:23:54 PM
Lund Machine Works,
See you've got some pics on the website of the old Reeves I used to own. What all is being done to it? I had heard at one point it was going to get a new boiler, is this right, or did MK change his mind?
Mike McKnight
Old 11-18-2005, 06:13:11 PM
Jim Jake Templin
I don't know how the dry pipe comes out of Advance engines, but on steam locomotives, it is a ground joint. Let me tell you, I have spent ALOT of time with Cloverleaf compound working really big fittings.
aint' what we do fun!?!
Old 11-18-2005, 10:17:01 PM
Mike, the Reeves is going to get a new firebox, barrel, tube sheet, and probably a wet bottom, and other thing that looks bad. The wagon top, backhead and the steam dome is what we are anticipating to re-use.
Jeff Lund
3hp associated engine truck number 2 fabrication hopefully uk-keith Antique Gas Engine Discussion 4 12-08-2007 04:45:50 PM
what is the contact info for Oliver boiler and Stutzman boiler? MarkP Steam Stationary Engines, Traction Engines, Steam Boats 4 10-03-2006 07:44:37 AM
Witte head: fabrication or wait RHudson Antique Gas Engine Discussion 2 06-16-2005 09:00:11 AM
magnets/fabrication martin reed Generators & Electric Motors General Discussion 1 05-29-2001 09:04:26 AM
