Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
Single cylinder, water cooled, unidentified engine
this thread has 5 replies and has been viewed 689 times
Old 04-26-2018, 11:41:12 AM
Maytag Maytag is offline
Default Single cylinder, water cooled, unidentified engine
No governor, no water pump, missing timer. Possible water pump engine?
"Old Marine Engine" forum doesn't think it is a marine engine.
Name:	CIMG2167 (Mobile).JPG
ID:	309122   Click image for larger version
Name:	CIMG2168 (Mobile).JPG
Old 04-26-2018, 01:42:20 PM
Default Re: Single cylinder, water cooled, unidentified engine
I'd still swear it was marine oriented. Mount, extra heavy flywheel, piped I/O water jacket and reduced speed output all too consistant. (Notice output shaft on cam? Reduced 2:1.) Exhaust piped for submerged output.
Would sure like to see pics of other two views.
Doc
This line left intentionally blank...
Old 04-26-2018, 03:22:43 PM
Thanks, Thaumaturge... It has no markings of any kind. Here are a couple more pictures.
ID:	309133   Click image for larger version
Old 04-27-2018, 04:05:50 PM
RustySteele RustySteele is offline
It looks like an engine that was used on some of the early light plants. I agree that it isn`t marine, the extended camshaft in the back is too small to run a prop, it might have run a water pump for cooling.
Old 05-14-2018, 05:36:35 PM
miro miro is offline
With a 2 cycle engine - if the exhaust is submerged, you would never get it to start - the exhaust port is blocked..
Once a 2 cycle is running, then yes a submerged exhaust is OK.
On more modern outboard engines , you'll find a small set of ports just above the waterline that lets enough exhaust out so that it fires.
miro
Old 05-14-2018, 10:41:42 PM
PFT's Avatar
PFT PFT is offline
Images: 31
The only thing that makes me think it is not marine is the raised output shaft. On marine engines they usually want the shaft as low as possible, but this might be an exception.
PT
Single Cylinder, Water Cooled ID grif Antique Marine Engines and Outboard Motors 4 05-31-2017 05:55:19 PM
Help ID Single Cylinder Water Cooled grif Antique Gas Engine Discussion 3 05-18-2017 07:50:13 AM
Unidentified Fairbanks Morse single cylinder diesel, radiator cooled yellowlister Vintage Diesel and Oil Engines 29 04-18-2017 12:17:24 PM
Onan Single-Cylinder water-Cooled generators ListerDiesel Onan Generators 4 11-16-2008 04:22:57 AM
Single Cylinder water cooled maytag???? Rex Pyles Maytag Engine Collectibles 15 03-28-2005 07:49:28 PM
