Fuel tank capacity of the enclosed 2.5LK
this thread has 8 replies and has been viewed 465 times
Old 03-18-2017, 02:23:07 AM
Motorhead's Avatar
Default Fuel tank capacity of the enclosed 2.5LK
Anyone know the fuel tank capacity of the oblong fuel tank on the enclosed 2.5LK I bought a month ago? It is the same tank that the CCK enclosed sets used. Is it a 3 gallon or 5 gallon?
The Control panel
and gauges of my
7.5JB
Old 03-18-2017, 04:23:18 AM
Billy J Shafer's Avatar
Default Re: Fuel tank capacity of the enclosed 2.5LK
They are 4 gallon tanks. If I remember correctly.
Old 03-18-2017, 11:32:27 AM
Motorhead's Avatar
Thanks Billy. I have had to do some cleaning to get the tank clean with acidic solutions. It is still real thick metal but I am thinking of putting in some tank sealer to prevent it from rusting inside again. The coatings used, you buy according to the tank size. Chris
The Control panel
and gauges of my
7.5JB
Old 03-18-2017, 12:18:32 PM
Pauls12 Pauls12 is offline
Motorhead, you can use formula... cubic ft x 7.47= gal
The Following User Says Thank You to Pauls12 For This Post:
Old 03-18-2017, 03:32:28 PM
Motorhead's Avatar
That's a little above my pay grade!
I measured the tank. Tank dimensions 17" long x 16" tall x 6" wide. Came up with 1632 cubic inches. Looked up a conversion to convert cu in to cu ft. Came up with .9444444 cu ft. I multiply by 7.47 and come out with 7.05 gallon? Seems like the tank is smaller than 7 gallon. Did I do it right?
The Control panel
and gauges of my
7.5JB
The Following User Says Thank You to Motorhead For This Post:
Old 03-18-2017, 04:40:39 PM
YEP!! Thats it. I used to work in water/wastewater, had to use formula everyday. Forgot more than I remember though.
Old 03-18-2017, 04:48:17 PM
Hey I was only three gallons off
It is even worse paul. When you remember something and forget where you remember it from.
The Following 3 Users Say Thank You to Billy J Shafer For This Post:
Old 03-18-2017, 08:19:38 PM
armandh armandh is offline
in inches HxWxL
now divide by 1728 [cu in per cu ft]
and multiply by 7.48052 [gal per cu ft]
or fill it and empty into measured containers
The Following User Says Thank You to armandh For This Post:
Old 03-31-2017, 10:54:04 PM
Motorhead's Avatar
I am getting ready to use a two part sealer in the tank to preserve it even though there are no leaks.
SO... I decided to check the volume of the tank by filling a gallon jug with water and filling the tank. The tank holds 6.4 gallons to the neck (+-) a 1/10th
I'd say 6 gallons with some expansion air space. I re-dried it out and in a few days, I will post how I cleaned the tank and sealed it.
The Control panel
and gauges of my
7.5JB
Detroit diesel fuel filter and oil capacity gtdownonit Multi-Cylinder Stationary Engines and Power Units 2 02-08-2016 11:02:11 PM
2-71 loss of fuel pressure from fuel tank-check valve? or bad fuel pump? Walter J. Generators & Electric Motors General Discussion 18 08-24-2011 09:22:40 AM
Tank capacity, Lister J?? B. K. Lahey Vintage Diesel and Oil Engines 7 06-30-2006 11:22:57 AM
CAPACITY of John Deere Fuel Tanks DICK STAATS Antique Engine Archives 2 02-29-2004 09:05:05 PM
cooling tank capacity... how much ? Marty Antique Engine Archives 7 04-12-2003 09:36:27 AM
