What Have You Done to Your Onan Generator Today?
this thread has 4096 replies and has been viewed 267571 times
Old 03-17-2017, 10:58:33 PM
Default Re: What Have You Done to Your Onan Generator Today?
I like oldstuff
{Originally Posted by Max Thompson
Not another word about me sitting on the floor beside the JC for hours at a time.}
Beautiful!
Originally Posted by Wayne 440 View Post
And at that moment the temperature in a substantial portion of Missouri dropped considerably...
You guys are funny!
Old 03-18-2017, 06:41:31 AM
^But you know Max will pay for that out maneuvering down the road. Women keep score, guys just want them to go away and be left alone.
The Following 2 Users Say Thank You to I like oldstuff For This Post:
  #3003
Old 03-19-2017, 06:07:44 PM
yellowlister yellowlister is online now
Email NOT Working
I picked this 1989 5.0 cck up for 200 bucks.. tri fuel.. from a big generator repair company that could not get it to start.. has a Ford start solenoid on it..
supposedly professionals.. but all there stuff was new and they rent them.. he has another cck in a in closure that has a dead cylinder and wants me to fix and has no idea what's causing low compression..
ID:	277950   Click image for larger version
ID:	277951   Click image for larger version
The Following 3 Users Say Thank You to yellowlister For This Post:
  #3004
Old 03-19-2017, 06:46:28 PM
Email NOT Working
Looks like it's never ran on gasoline before..
ID:	277957   Click image for larger version
ID:	277958   Click image for larger version
The Following 5 Users Say Thank You to yellowlister For This Post:
  #3005
Old 03-19-2017, 10:30:06 PM
Man Joe, you are DA MAN!!!! Nice score!
The Following User Says Thank You to nothingbutdarts For This Post:
  #3006
Old 03-19-2017, 10:45:28 PM
JohnnyC JohnnyC is offline
Your like a blood hound trained to sniff out Onans. Nice catch, as always! 5.0 CCKs are nice heavy iron gennys as you know. What does this make for the month of March? Do you ever run out of room over there?
JohnnyC
New Jersey
The Following 2 Users Say Thank You to JohnnyC For This Post:
  #3007
Old 03-20-2017, 05:28:46 AM
squidtrap squidtrap is offline
That NH is still for sale by me that i looked at for JohnnyC, 300.00 but will take 200.00 cash.
If add states that 100.00 w/take it. real tempting, prob just the norm tune up and off it goes. 3 min. from house
Old 03-20-2017, 08:47:10 AM
TLB01 TLB01 is offline
Got the MDKC offloaded since the rain finally took a time out. A 30+ year old machine only gets 286 hours on it by doing a BUNCH of sitting around, and sure enough....the coolant had partially evaporated with only the block actually filled still with good green coolant. Even then, the outlet to the pump was all gooped up. The water pump was full of gelatinous slime and the water neck as well as the manifold tank were full of coolant crystals. The lid on the tank and the thermostat crumbled once disturbed from their 30 year nap. The water neck and the pump were trashed.
I took the cheesy plastic intake resonator off, since it was only held on with one bolt and also took off the marine exhaust manifold as well as the heat exchanger.
So, the shopping list (other than muffler, battery and radiator set up) grows to water pump, thermostat housing, exhaust manifold, Donaldson or other suitable air cleaner and fuel solenoid relay.
The raw water pump is still mounted as well. The flange on it is 1/4" thick or so and either requires a beefy aluminum block off or some purpose made item from Kubota. Either way, the fuel solenoid will need adjustment. Not sure if I want to get into that just yet, or ever. Unless the raw water pump is water lubricated/cooled, I just assume leave it unless anyone has better advice.
The Following User Says Thank You to TLB01 For This Post:
  #3009
Old 03-23-2017, 04:34:46 PM
Handyhiker1 Handyhiker1 is offline
I loaded the 12.5jc that I pick up a few weeks ago. I could only load it with 22 amps but it did okay. The rpm did drop some so I went to adjust the carb and that is when I broke it. The main needle valve on the bottom of the float bowl broke. The little nut around it just fell apart from corrosion. So I will be looking for a main jet assembly and the run/stop solenoid. Oh well, at least it pulled some amps and still runs good.
Old 03-26-2017, 01:11:54 PM
scoops scoops is offline
nice day, decided to fire up the 5cck and look at the wave form.
this was at no load.Click image for larger version
Saw this generator hook up cord in ad today. len k Onan Generators 40 07-09-2016 10:10:20 PM
onan 10 cw on cl today, cheap Mikey NY Onan Generators 1 08-21-2014 09:09:51 AM
saw an Onan today the likes of which I've never seen before armandh Onan Generators 12 04-27-2014 04:44:41 PM
Got old Onan genset today,no id tag. p fears Onan Generators 4 05-03-2009 09:56:02 AM
old aircraft generator followed me home today clifton clowers Generators & Electric Motors General Discussion 4 11-21-2003 11:39:36 AM
