Onan Emerald 1 Genset Manual
this thread has 57 replies and has been viewed 33380 times
Old 01-23-2012, 10:34:05 PM
mbb111 mbb111 is offline
Default Onan Emerald 1 Genset Manual
I just got a onan gen. It's a onan emerald 1 Genset Serial # 1890266962 Model # 4BGEFA26100F RPM 800 volts 120 PH.1 It starts and runs but seems like it might need a tune up, idles a little rough. Also the the off switch does not turn it off. I have to unhook the battery. So I have a couple of questions what year was it made? and I can't locate a free service manual. Thanks for any help you can give me. Also it doesn't seem to be putting out any power to the supply wires. If there are no free manuals , where can I buy one? I've searched but the ##'s dont seem to match up.
Thanks, Mel
Old 01-23-2012, 11:31:21 PM
Default Re: Onan emerald 1 genset manual
http://www.cumminsonan.com/www/pdf/manuals/965-0528.pdf
The above link should get you the service manaul for the BGE spec. F-K.
Could the first digit in your ser. # be an I insted of a 1? This would make it Sept. of 1989, if it is a 1, it would be Jan. of 1989.
The manuals can be very slow to load, give it some time.
Old 01-25-2012, 01:10:28 AM
Max,
Thanks I printed the manual today at work. Haven't had time to look trough it yet. Do you no if the gen. charges the battery or does thr RV do that? When I hook up a battery to it on the bench and push start it fires right up, but when I push off it keeps running. When I remove the battery cable from the bolt under the start awitch the motor dies.
Thanks, Mel
Old 01-25-2012, 08:08:41 AM
tekrsq tekrsq is offline
Max,
Do you have a link for the "C" spec ? I also have the Emerald 1, but I think I have the C spec. My model is 4.0BGE-1R/26100C.
I couldn't negotiate the above site to find the manual.
Thx.
Old 01-25-2012, 08:41:55 AM
#965-0528 BGE Emerald Plus series, spec A-K is available for the price of an e-mail address. One of us will send it to you if you will post or PM an address.
Originally Posted by mbb111 View Post
Max,
Thanks, Mel
I nearly forgot this, in general it is not adviseable to disconnect the battery from a running genset.
The Following User Says Thank You to Max Thompson For This Post:
Old 01-25-2012, 11:36:47 AM
PM sent, THANKS !!!!
Old 01-09-2014, 05:38:38 AM
AngelicaParker AngelicaParker is offline
Originally Posted by tekrsq View Post
Max,
Thx.
I have this exact generator, needing this same link, if it's not too much trouble, pretty please? It would be most appreciated!
my email address is: angelica.parker@ymail.com
Old 01-09-2014, 06:03:12 AM
Kevin K Kevin K is offline
Manuals sent: 965-0530 service & 965-0232 parts.
Old 01-27-2014, 03:42:00 PM
thguan thguan is offline
looking for service and parts manual for Emerald I genset 4.0 BGE-1R/26100C
Serial no. G870908376 4kw 120 V. amp 33.3 60hz rpm 1800 can someone help
thanks in advance. jsmcnaught@optimum.net
Old 01-28-2014, 03:49:57 PM
Onan Emerald Genset Help skydrojas Onan Generators 13 08-19-2017 10:58:53 AM
New & need manual =Onan Emerald 1 Genset ' C ' jj69 Onan Generators 0 07-24-2014 12:06:00 AM
Onan 4BGE Emerald 1 Genset Manual Needed N5OE Onan Generators 12 03-17-2013 11:04:17 AM
onan emerald 111 genset 6.5 nhe fa 26100e wirng diagrams and service manual needed chersthebest Onan Generators 0 10-16-2012 02:22:23 PM
Onan Emerald III genset Yngbld14 Onan Generators 6 08-12-2011 01:06:34 AM
