Fuel starvation problem?
this thread has 29 replies and has been viewed 2627 times
Old 10-21-2014, 12:09:54 PM
Isaac-1 Isaac-1 is offline
Default Re: Fuel starvation problem?
If you do plumb a natural gas line from the house you will also need to make sure it is big enough, and that your existing natural gas meter is big enough to handle the load of the JC while running your other natural gas loads. Natural gas is delivered at very low pressure so typically needs a rather large pipe.
Old 10-21-2014, 12:26:32 PM
JohnnyC JohnnyC is offline
That is what I need to investigate. More question will follow as I roll my 700 green monster closer to it's fuel supply line. I will check CL for used 100 lbs propane tanks and regulators. If I can find something cheap, I will use it for testing and a backup fuel source.
JohnnyC
New Jersey
Old 10-21-2014, 12:58:57 PM
Doug Reed Doug Reed is offline
Info regarding pipe sizes for Propane and nat gas are in the T-015 manual. If I remember right, someone else was checking that within the last few months and I think his answer was a pipe over 1" diameter for 100'. As for the regulator on the house, it was a bit small for running both the JC and his furnace-water heater. You've still got lots of interesting things to check out....
Old 10-21-2014, 01:09:19 PM
len k len k is online now
IF you had enough 20# tanks and BBQ regs you could gang them up after the reg. I'm guessing maybe 6-7 will do it. Look for grills on the curb on trash day in a rich area in spring, I've picked up > 20 free tanks and regs that way.
With valve to engine off, have to open the tank valve SLOWLY so it doesn't trip the excess flow safty.
Old 10-21-2014, 01:54:30 PM
I must be shopping in the wrong store..... When the free scrap grills turn up on Craig's List around here they come without tanks.... I did get a 100# tank, empty, for $20, but it had been listed on CL as full for $75..... OTOH, 20 gallons of propane to fill a 100# tank should cost around $35-$50 in today's market. I should break down and get it filled.....
Old 10-21-2014, 02:07:27 PM
As I was driving one night, before I saw it, I smelled it. Guess they don't want you to throw out tanks full of propane in the trash. So some genius left the valve open on an old 20# tank and left it on the curb. Tank had no pressure, was ice cold -40 deg F. If you tipped it liquid propane could squirt out. Dangerous, frostbite and fire !! I shut the valve off and took the tank home. Burned fuel in my grill, and tossed the tank , it had the old style valve.
Old 10-21-2014, 02:50:31 PM
I did quick searched on CL and found several people selling left over underground gas pipe in lenths of 20 to 120 feet and ranging from 1 inch up to 2 inches. The left overs were from projects such as running gas to their garages, outdoor bbqs or fireplaces and they had to buy huge rolls. The left overs went for sale on CL for pennies on the dollar.
The question is I must determine the lenth I need to run my line to determine the size. I will check out the T-015 manual.
Another thought was to mount my 15.0JC in my basement and the gas line will not be a problem, nor mice problems. However, noise and the potential for gases can be a problem.
Winter is just around the corner and the ground will start to freeze making it difficult to bury anything. Maybe I will make a quick disconnect hose/line to go between the house and somewhere outside for a temporary but safe hookup.
JohnnyC
New Jersey
Old 10-21-2014, 03:12:46 PM
I've dug trench for cable pipe in Dec , but that was a mild winter. Dig it now before ground freezes. In early winter if it's a mild 30 degs and dry, ground will only surface freeze ~1/2 inch. That being said one early winter ~ Nov weekend it got cold with high wind and wet ground. I had a hard time hammer and chisiling thru 2" frozen soil to get my road reflectors in after just 2 days of cold.
Leaves over the ground to be dug help insulate it and keep it from freezing.
Old 10-21-2014, 04:27:51 PM
JohnnyC
New Jersey
My JB is sitting in the basement! Still need to get running however. ; ^ )
Old 10-21-2014, 05:56:02 PM
scoops scoops is offline
places around here would exchange that tank for you. I collect old ones when people throw them away and exchange them for new ones.
Petter AC1 Fuel Problem cowmechanic Vintage Diesel and Oil Engines 16 01-16-2014 06:21:03 PM
associated fuel loss problem MedicHamilton Antique Gas Engine Discussion 8 08-10-2012 12:37:54 PM
fuel pump Problem rodymartin Onan Generators 3 02-04-2012 07:14:59 PM
Maytag 92 Fuel Problem Frank Douglas Maytag Engine Collectibles 6 08-02-2006 05:50:31 PM
fuel bleeding problem dcameron Kohler Generators 2 07-13-2006 10:45:13 PM
