Overhead wiring?
this thread has 56 replies and has been viewed 2464 times
Old 10-14-2016, 07:35:42 PM
Vanman Vanman is offline
Default Re: Overhead wiring?
And one more thing- the center strand in the bare aluminum conductor in that triplex / quadplex is Steel. So don't use your favorite rabbit gun to cut it! I learned of this feature the hard way.
But it does allow it to be used with very long spans between supports.
The Following 2 Users Say Thank You to Vanman For This Post:
Old 10-14-2016, 08:58:50 PM
Sorry Joe, no dynamite! Too close to the house.
I am trying to dig, maybe down 12" in a lot of the 10' I have already dug, not sure I can get much deeper in places. If I put in 2" PVC for the electric runs, can a propane line be run in the same hole?
Old 10-14-2016, 09:12:19 PM
Graycenphil Graycenphil is offline
Originally Posted by yellowlister View Post
You have a 600 foot span of electrical cable just hanging there??????????
600 feet of coax, strung from tree to tree.
Old 10-14-2016, 09:28:29 PM
Ben Clarke Ben Clarke is offline
Here is a product that breaks up rocks but does not go BOOM.
http://www.ecobust.com/
i searched for nonexplosive rock breaking several options came up posted this as it had a video.
The Following 3 Users Say Thank You to Ben Clarke For This Post:
Old 10-14-2016, 09:29:13 PM
len k len k is offline
Think I read in electricians magazine you don't have to go 18 inches if you have 2 inches of concreat above the line. Guess 18 inches is insurance in case the ground errodes ( like on a hillside and water, or sand driveway plowed with a snow plow, eventually it digs down.)
One way I've seen rock quarrys "cut rock" is with 15 ft long pipes flowing gasoline and compressed air to melt the rock, but they usually cut it from the side so the lava can flow out by gravity. And in a rock quarry there's not much of anything flammable nearby so no real danger of fire..
Old 10-14-2016, 09:48:33 PM
Email NOT Working
http://www.xwalk.com/images/Table_30...over_Reqts.pdf
The Following User Says Thank You to Birken Vogt For This Post:
Old 10-15-2016, 03:08:05 AM
Can always do like one staker did step up voltage to couple KV and run 2 small bare wires overhead like utility does.
Old 10-15-2016, 03:18:59 AM
^ I have always wanted to do that!
Old 10-15-2016, 11:27:36 AM
I have a bunch of microwave transformers and actually briefly considered that once to temporarily get power across the street to where I wanted it. Figured one to step it up to 1500 V another in reverse and knock out the magnetic shorting lamination (current limiters). But when I thought about the risks if the wire fell I decided wasn't worth it.
Thinking about it makes you think of all the safety measures the utility uses when they do that. Very strong wire , structurally strong insulators and poles, ect....
Old 10-15-2016, 12:03:51 PM
Email NOT Working
And a body of laws from an earlier time when people were expected to have the sense not to handle bare, down wires.
Homemade overhead shop crane Grant McEwan Machine Shop and Tool Talk 12 09-27-2011 10:45:16 AM
Engine Trailer - overhead I beam Tilinghast Trucks, Trailers and Hauling for Shows 8 07-01-2009 03:58:43 PM
Overhead with 7018 George White Welding Shop 13 05-27-2009 09:57:28 PM
Briggs FH Overhead valve engine HerbyReed Small Air Cooled Gasoline Engines 6 02-19-2009 07:17:54 AM
