Overhead wiring?
this thread has 56 replies and has been viewed 2543 times
Old 10-15-2016, 12:08:24 PM
len k len k is offline
Default Re: Overhead wiring?
Pet animals and young children are the real risk.
Old 10-15-2016, 12:17:48 PM
Email NOT Working
Originally Posted by len k View Post
Can always do like one staker did step up voltage to couple KV and run 2 small bare wires overhead like utility does.
I'd like to see this. Link?
Old 10-15-2016, 12:35:48 PM
Pic of it was on the Stak ~ 3 months ago, don't remember who had it. Think it was in the woods. Small gauge bare stainless?? wires were about 1-2 feet apart, small white knob type porcelain insulators. Did concern me that the wires were small enough gauge to be taken out by a falling branch, then they would be on ground. Not sure if current breaker would trip then.
As a kid in late spring I've put a 1 ft steel rod in ground and connected it to 120 hot to get worms for fishing to come out of ground, think it drew under 3 amps, maybe 1 amp. Was pretty low current, soil was clay. Wore rubbers and kept my feet together. Had to keep reminding myself when I saw a big worm I wanted to reach for , pull the plug first. . Surprising how fast they disappeared back in their holes when I shut AC off.
Old 10-15-2016, 12:59:03 PM
Nope, not looking to use bare wire!
I'll do more digging today and see how that goes and decide.
Old 10-15-2016, 01:59:23 PM
Vanman Vanman is offline
Was thinking about this last night, just for fun.
One way to improve the safety dramatically- though probably at some expense of reliability- would be to have a mid-point tap on the secondary of the step up transformer, and ground it through a very high resistance.
Connect the coil of a relay across this resistance, and arrange the circuit such that if the relay pulls in, it trips the circuit off line. Thus the slightest ground fault takes the circuit off line. A high voltage GFI.
Also for fun, I calculated that 5 KVA could be transmitted one mile using 15 KV with only ~4% loss using #34 wire! *Ridiculously* fragile, but illustrates the usefulness of high voltage.
Old 10-15-2016, 03:32:34 PM
Old subs supposedly had a version of that , but they just leave the power on and use an indicator light to highlight trouble that a hot is grounded.
Some country ( Australia ??) uses a system of only one hi-voltage wire. And a ground rod for the return current to save wire costs out in the boonies. Actually that was the system I briefly thought about using.
Old 10-15-2016, 08:25:53 PM
soundbos soundbos is offline
The feed to my brothers house is 1 wire to a transformer and earth ground and this is only 6 years ago in Illinoise
I think it is 6kv
Butch
Old 10-15-2016, 08:37:49 PM
In the Australia system I read the wire was MANY MANY miles long. So they used some type of voltage regulation at the user's step down transformer, to compensate for losses in the hi-voltage wire. Maybe an automatic multitap transformer.
And they did a special ground rod , think they used salts to increase soil conductivity to get a good ground. Since if had poor ground connection to earth the rod could be hot WRT earth under your feet, if you touched it.
Old 10-15-2016, 09:05:15 PM
SoTexRattler SoTexRattler is offline
Yeah, a couple small "Pole Pigs" connected back-to-back would carry 120/240V 5kva a LONG way with little loss.
5KVA over #34 wire @15KV you say? COOL! That would definitely open up a wide choice for HV conductors!
Tiny pole pigs they use for powering a single billboard or traffic light out in the country would be perfect.
Old 10-16-2016, 03:48:56 AM
turtmaster turtmaster is offline
i have also always wanted to run a mini high voltage line
one problem that one might have with using a microwave transformer is i think that the way they are designed with respects to it's losses that it would get hot quickly under load
also here is a link to a homemade mini high voltage transmission line in Chile
https://ludens.cl/paradise/turbine/turbine.html
also the Australian system is called "single wire earth return" sometimes no. 10 fence wire is used
The Following 6 Users Say Thank You to turtmaster For This Post:
Homemade overhead shop crane Grant McEwan Machine Shop and Tool Talk 12 09-27-2011 10:45:16 AM
Engine Trailer - overhead I beam Tilinghast Trucks, Trailers and Hauling for Shows 8 07-01-2009 03:58:43 PM
Overhead with 7018 George White Welding Shop 13 05-27-2009 09:57:28 PM
Briggs FH Overhead valve engine HerbyReed Small Air Cooled Gasoline Engines 6 02-19-2009 07:17:54 AM
