Ex-Military Spec 6JB compression issue
this thread has 84 replies and has been viewed 3071 times
Old 02-09-2017, 12:05:06 PM
MadGutts MadGutts is offline
Exclamation Ex-Military Spec 6JB compression issue
Hi Guys,
I have had this genset for about 3 months and it was running superbly for the last 2 months... Yet a couple of days ago i started it in the morning and used it for a couple of hours and then turned it off as normal...
Sometime later about 4pm i sterted it back up but it took some starting and wasn't sounding right... turns out is was only firing on one cylinder - it has only done 455 hours so not due a major overhaul yet... but i switched it off and had a quick look over it...
Turning the engine over by the crank i could get get good compression but on the next rotation i could hear air hissing on the compression stroke, then roated to the next compression was good again... So decided to whip the head off..
So after reading these forums, and people saying the valve seat to be an issue, we cleaned the head which was badly coked up and we reset the valves and re ground in the 1st cylinder... all nice and clean and well seated.
Checked the inside of the cylinder to make sure no damage/scoring etc on the inside... it all looked and felt fine, so removed the coked ring around the top and cleaned it all out, re-assembed the head with the old steel gasket and turned over by hand, still had a hissing on piston 1... so took all apart again and have now put some diesel in the cylinders to see if there is a piston ring out...
Since im guessing this is going to be the fault... is there any one on here who has done this job on their engines?
basically this is a heavy lump and i don't have an engine crane to lift this of the cradle and turn on its side/end while i remove the bottom cover to get access to the crank and the big ends...
So is there an easy way? should i check anything else first?
thanks in advance - oh probably should mention im in the UK so parts are like rocking horse poo over here now
Old 02-09-2017, 12:19:09 PM
Default Re: Ex-Military Spec 6JB compression issue
I doubt you are missing anything having done the valves, but a good check is to put that piston at TDC of compression stroke and while holding it securely with a wrench, apply compressed air to it through the spark plug hole. The air will leak from the rings and you will want to compare the noise between the good and bad cylinders. But if you have a valve or head gasket problem, you will quickly pick up on it.
The Following User Says Thank You to Jim Rankin For This Post:
Old 02-09-2017, 02:26:01 PM
nothingbutdarts nothingbutdarts is online now
Yes as Jim mentioned, do a leak down test at TDC. Either with a meter if you have access to one or just by putting air pressure in the plug hole with a rubber tip air nozzle. + You will want to listen to the three areas, intake side, exhaust side and pull the dipstick and listen in the crankcase. See where the most hissing is coming from before taking it apart again.
The oil pan has to come off to get the pistons out.
Old 02-09-2017, 02:42:59 PM
Question Re: Ex-Military Spec 6JB compression issue
thanks guys,
i have already taken the head off as when turning it over there was compression, then turned it over again after setting the rockers and lost the compression!
So with head off, put some diesel into both cylinders and let it rest for a bit.. an hour later and all diesel in 1st cylinder had gone! so deffo a piston out job now
to get the sump off, it will have to come of the cradle... but do i need to take anything else off to do this? - blower shroud etc? the service manual is not too descriptive!
and if i stand it up on the alternator end, will that be ok on the end while i do this?
Old 02-09-2017, 03:09:03 PM
Billy J Shafer's Avatar
I have changed pistons in the field. It will have to come out to where you roll it over.I would remove any shields that might bend. Have two good blocks of wood to lay the block on.
Old 02-09-2017, 05:42:25 PM
BRae's Avatar
BRae BRae is offline
Very strange, running just fine when shut down only to be running low on compression the next day? Could carbon have gotten into a ring? I think I would try a a good penetrating oil. Maybe that could dissolve some carbon and get the seal back. Did you notice a lot of blow-by in the breather?
Old 02-09-2017, 06:01:43 PM
Will have to find some good blocks then! got to be easier on its side than stood on the alternator! lol
So next question, im assuming i will need a new set of rings... but what size should i buy? with only 500 hours on the clock, surely its never been honed so an oversize set shouldnt be required should they?
Old 02-09-2017, 06:08:00 PM
LRomero LRomero is offline
I pulled the pistons out on my 4.0CCK by standing the unit up on the alternator end. I used some wood blocks I have laying around and was able to shim it pretty steady. I used a strap/chain from the ceiling for extra safety to keep it from tipping over too. The strap twisted as I turned the flywheel to get the crank turned. Worked perfectly.
Old 02-09-2017, 06:46:06 PM
Power Power is offline
See what you got first.
To have that big a loss of compression, probably more than just ring.
May have broken land(s)
Very likely if someone used Ether in the past.
The Following 3 Users Say Thank You to Power For This Post:
Old 02-09-2017, 09:00:50 PM
excuse my ignorance... broken lands?
1 1/2 HP Compression Issue Dylan K Antique Gas Engine Discussion 5 01-01-2016 12:41:19 PM
Mogul 8-16 Compression Release Issue tirediron Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 11-08-2015 01:08:02 PM
Onan 4.0 BGE Spec K Compression masterfabr Onan Generators 2 10-23-2012 11:51:53 PM
Honda GX160 crankshaft swap Timing Issue:Zero compression Subzero Small Air Cooled Gasoline Engines 13 09-04-2012 07:18:41 AM
Military issue MEP-003A Unit Merc300SD Military MEP and Aircraft Gen-Sets 17 11-19-2008 10:46:35 PM
