Ex-Military Spec 6JB compression issue
this thread has 84 replies and has been viewed 3186 times
Old 02-09-2017, 09:26:10 PM
lokay5's Avatar
lokay5 lokay5 is offline
Default Re: Ex-Military Spec 6JB compression issue
The "lands" are the portion of the piston between the ring grooves.
The Following 2 Users Say Thank You to lokay5 For This Post:
Old 02-10-2017, 12:09:47 AM
Jim McIntyre's Avatar
I'm probably wrong, but I guess I'm a little surprised that a little loss of compression would cause total misfire on one cylinder.
First, what does the compression actually measure? - I could be convinced this is the issue, but need some evidence.
Second - did you swap plugs and plug wires to make sure the 'low compression' cylinder remained the non-firing one?
Ignition issues are common. Low compression, especially all-of-a-sudden, not so common.
Lastly, any other signs of low compression i.e. crankcase blowby overwhelming the breather, or oil blowing out anywhere?
Old 02-10-2017, 12:23:43 AM
nothingbutdarts nothingbutdarts is online now
Diesels are just a compression/ combustion engine, if compression gets low it will not get hot enough in the cylinder to fire the atomized diesel if it is a djb, I do not know which one it is.
Old 02-10-2017, 12:36:39 AM
I am seeing "6JB" in the title- to me that is a spark ignition engine.
---------- Post added at 10:36:39 PM ---------- Previous post was at 10:25:45 PM ----------
To me, this unusual-
Originally Posted by MadGutts View Post
...when turning it over there was compression, then turned it over again after setting the rockers and lost the compression!...
I have done more than a few valve clearance adjustments (I'm assuming that "setting the rockers" is a term for same) and have never had a cylinder suddenly lose compression due to the process.
Old 02-10-2017, 01:05:00 AM
Zeromedic Zeromedic is offline
Maybe no compression on next rev after adjusting valves because that cylinder now coming to
TDC on exhaust stroke?
Steve
Old 02-10-2017, 01:22:31 AM
Originally Posted by Wayne 440 View Post
I am seeing "6JB" in the title- to me that is a spark ignition engine.....
Me too. Ignore my post if this is a Diesel...
Old 02-10-2017, 05:10:13 AM
MadGutts MadGutts is offline
Morning guys,
Yes its a petrol fired engine... sorry for the confusion - i put diesel in the cylincders to test the rings, low and behold the 2nd cylinder is still full, nothing in the first, so obviously its leaking somewhere..
There are no marks on the inside of the cylinder and its all freely moving, so next job is piston out to investigate further
I hope its not the piston that has had it as parts are not easy to find in the UK!
Old 02-10-2017, 09:44:39 AM
...2nd cylinder is still full, nothing in the first, so obviously its leaking somewhere...
Agreed - just not convinced that this leakage is the cause of that cylinder not firing. Did you swap plugs and plug wires to make sure the 'low compression' cylinder remained the non-firing one?
Old 02-10-2017, 10:34:17 AM
grif grif is offline
I'm an old ford guy, unless these thing are a lot higher performance than a ford 6 (not likely ;-) it should run just fine with enough blowby to soak everything with oil closer than 10 feet, and sound like it's running fine.
I'm with Jim. (and my dad). Simple stuff first. And breaking into a block was the very last thing he wanted to do.
The Following 4 Users Say Thank You to grif For This Post:
Old 02-10-2017, 12:21:56 PM
len k len k is offline
Are you sure you were at TDC when you adjusted the valves. Doesn't take much open valve to lose compression. On my single cylinder 10 hp snow blower ~0.005 inch always open valve will drop compression to ~ 50 psi and it won't even start.
1 1/2 HP Compression Issue Dylan K Antique Gas Engine Discussion 5 01-01-2016 12:41:19 PM
Mogul 8-16 Compression Release Issue tirediron Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 11-08-2015 01:08:02 PM
Onan 4.0 BGE Spec K Compression masterfabr Onan Generators 2 10-23-2012 11:51:53 PM
Honda GX160 crankshaft swap Timing Issue:Zero compression Subzero Small Air Cooled Gasoline Engines 13 09-04-2012 07:18:41 AM
Military issue MEP-003A Unit Merc300SD Military MEP and Aircraft Gen-Sets 17 11-19-2008 10:46:35 PM
