Ex-Military Spec 6JB compression issue
this thread has 84 replies and has been viewed 3079 times
Old 02-10-2017, 12:55:53 PM
Default Re: Ex-Military Spec 6JB compression issue
You have to set the valves at TDC Compression stroke. Could by accident, you set the valves at TDC between exhaust and intake? If so, clearances will not be correct. The fact that liquid is getting past the rings, means there is a mechanical problem. Bad or stuck rings in the ring groove, carbon on the rings, broken rings, worn out compression rings, bad piston. All mean the piston has to be pulled. It may be as simple as freeing and de-carboning the rings, to as complicated as replacing the rings and piston. I would also check that there is no carbon under the valve faces. If you have to replace rings, do both sides, as if one side is worn, then chances the other side will be worn too, even though it is now holding. You need all cylinders to have compression within 10% of value to each other, or you will have a work imbalance that will cause overheating in the good cylinder after the one with poor power, as the good cylinder tries to make up for the power loss. As an example, if the highest cylinder pressure has 100 PSI, the others need to be within 10 PSI. I would do a leakdown test to be sure you are not losing pressure thru the valves. You may have several issues here, both valve seating and ring issues. Personally, I would check both while you have the heads off.
There are several products that state they can free stuck rings, found at auto stores. One here in the US of A is Sea Foam Ring Free. Over on your side of the pond, there may be a comparable product. For myself, I don't take much stock in such products. Only a physical teardown can tell you exactly why you are losing compression or fluids past the rings. Let us know what you find.
Old 02-10-2017, 03:22:37 PM
In reality, since he says one piston is holding the diesel fuel he put in both cylinders and the other cylinder is leaking out I am going to take a wild guess and say he has a cylinder sealing problem and not a leaking valve issue.
However, just to bolt the head back on without adjusting any valves and doing a leakdown test should take less than 30 minutes for peace of mind.
The Following User Says Thank You to nothingbutdarts For This Post:
  #23
Old 02-10-2017, 05:52:03 PM
MadGutts MadGutts is offline
I hadn't touched the engine prior to it losing compression...
im the old skool - if it aint broke dont fix it!
But alas compression had gone from the 1st cylinder, and normal compression on 2nd... cranking by hand gives good resistance but second rotation nothing, ther should be compression on every rotation.
So today the piston came out, and it all looks fine, there is a slight difference in the gap between the open compression rings, 2mm at the most, and the oil seal looks ok too... no damage to bore or to piston...
The top compression ring is polished (shiney) but the second one is dirty in places... Could this be a tell tale?
other than that i cannot see anything bad on the piston, rings or bore!
Old 02-10-2017, 06:49:47 PM
grif grif is offline
Valves are free?
Old 02-10-2017, 06:56:51 PM
yeah thoroughly checked top end before going to the bottom end! valves checked and reseated
and putting diesel in both cylinders to test for leaks, all diesel dissapeared from 1st cylinder, so there is a leak down the side of this piston
but i cannot see any faults
Old 02-10-2017, 06:58:34 PM
BigBlockChev's Avatar
What is the ring endgap on each ring when they are inserted about 1 inch down the cylinder. 2mm is a huge endgap for rings , about .080, the manual calls for .010 to .020. What do the cylinder walls look like , do they still have a bit of crosshatch. Is there a ridge at the top of the cylinder? What is the taper on the cylinder top to bottom. What is the piston skirt clearance? Are the rings free to move in the ring lands not stuck in the compressed position. To me catastrophic compression failure means , burnt valve, misadjusted valve, broken rings, rings stuck in retracted position, broken ring lands, broke piston skirt, loose head bolts or blown head gasket. The fact that diesel leaks past the rings when it is sitting does not indicate to me that it has enough wear to completely lose compression, these are very low compression engines. I would bolt the head back on and do another compression test but squirt a bit of oil in the cyl to see if that brings up the compression substantially , or do a leakdown test as others have suggested to identify the source of the leakage. Show us some pics so we can see what you have been finding. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
The Following 2 Users Say Thank You to BigBlockChev For This Post:
  #27
Old 02-10-2017, 07:13:18 PM
If it were me,,, I'd swap plugs and wires after making sure there was spark available for both cylinders.
We're missing something easy here. (I can hear my dad).
The Following 2 Users Say Thank You to grif For This Post:
  #28
Old 02-10-2017, 08:49:27 PM
Motorhead's Avatar
Fisrt, If the valves were adjusted at the wrong TDC then they would be clattery as all get out running. We had people trying all the time to adjust their own valves on air cooled VWs and had more than one guy come in with the car sounding like it had BB's running through it. You would have to loosen the rocker nut a bit to get any clearance.
Second, if the 6jb is the same as a 7.5jb then it has a dual coil where both plugs fire at the same time, one cylinder getting a waste spark. So I would be inclined to test the spark by cranking the engine with the plug wires hooked to two spark plugs sitting external from the cylinder where you could see if you have spark at both plugs. This set might be a 6JB 50 cycle only running 1200 rpm?
Lastly, Big Block Chev has a good point to check ring gaps. A compression test would have been something I would have done first on both cylinders.
Back of 1958 5CCK
Contractors model
On trailer owned by
"Ma" Bell.
  #29
Old 02-10-2017, 08:56:15 PM
Originally Posted by grif View Post
...We're missing something easy here. (I can hear my dad).
Agree. I have been a victim of the "it can't possibly be..." line of thinking more than once.
So to me, the cause of the original problem is probably not that the rings won't hold liquid. I had a Ford 8N with so little compression that it would coast like the Wheel of Fortune when shut it off at idle, but it still pulled about as well as anyone else's. Was easy to start too, just put it in 2nd or 3rd, then reach over and give the back wheel a push.
  #30
Old 02-10-2017, 08:57:07 PM
David C David C is offline
Really needed to do a compression check before the initial teardown. The next step would have been to put each cylinder at TDC on the compression stroke and apply air to the cylinders and see where the air was escaping.
I can't imagine what would fail in the piston and ring area while shutting down. I have a well neglected and used 2.5LK that had a .250" (yes 1/4") ring gap on the rings and it would still run. It had some blowby and smoked some, but it would start and run fairly well considering the ring gap.
David C.
The Following User Says Thank You to David C For This Post:
1 1/2 HP Compression Issue Dylan K Antique Gas Engine Discussion 5 01-01-2016 12:41:19 PM
Mogul 8-16 Compression Release Issue tirediron Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 11-08-2015 01:08:02 PM
Onan 4.0 BGE Spec K Compression masterfabr Onan Generators 2 10-23-2012 11:51:53 PM
Honda GX160 crankshaft swap Timing Issue:Zero compression Subzero Small Air Cooled Gasoline Engines 13 09-04-2012 07:18:41 AM
Military issue MEP-003A Unit Merc300SD Military MEP and Aircraft Gen-Sets 17 11-19-2008 10:46:35 PM
