Ex-Military Spec 6JB compression issue
this thread has 84 replies and has been viewed 3074 times
Old 02-11-2017, 01:46:48 PM
Power Power is offline
Default Re: Ex-Military Spec 6JB compression issue
Good close up pictures of ring lands all around, top and underside of piston would answer some questions.
What you say about the second compression ring is odd, but even if it was not there, the top one would provide compression.
You should follow previous comment about putting rings in bore and squaring them. I would put all 3 rings in bore, and check ring tension, look for space between ring and wall. If you do not have tools to measure taper, square compression ring at top of bore and slide it down checking ring gap at intervals. The amount of change in ring gap tells you how much cylinder taper you have. Shine a light in cylinder when you check gap. In unlikely event you see light between cylinder and ring in places, then you have a warped bore. From my experience, that is most unlikely.
It is courteous to thank people who provide you with useful information. From my experience, you get better responses when you do.
The Following 2 Users Say Thank You to Power For This Post:
Old 02-11-2017, 01:53:50 PM
BigBlockChev's Avatar
The second ring does look a bit suspect and the top ring is chrome so it would look shiny even if it wasn't in full contact. You have to remove the rings from the piston and insert them into the cylinder individually by themselves . Push them down using the top of the piston till they are about 1 inch down in the cylinder then use a feeler guage to see what the endgap is in the installed position. It is possible that the rings have lost their tension due to overheating but I wouldnt expect that to come on suddenly. What I find puzzling is the uneven wear on the second ring ,some spots it is shiny some it is not. . I am leaning towards a quick deglaze hone and trying to see if that seats the rings. I would use a ball hone to deglaze. It does look like someone has had the engine apart before as the blue stuff is not original I think. Would also be good to verify that he rings have been installed right side up in that case. I have been bit by that before. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
Old 02-11-2017, 02:02:51 PM
Motorhead's Avatar
Question to MadGutts and others here, The second ring looks suspicious to me as to its contact wear. I know from some engines the rings are directional. Is there marks on the rings for direction of installation? Could the second ring be upside down? If there are directional marks, they are usually right next to the gap.
Dan ^ was writing at the same time I was. He hit the reply button before I did. Looks like he and I are on the same wave length. That SECOND ring is not right.
Look at the first drawn diagram on this: http://www.hotrod.com/articles/hrdp-...ton-ring-tech/
Back of 1958 5CCK
Contractors model
On trailer owned by
"Ma" Bell.
Old 02-11-2017, 03:15:42 PM
To avoid problems, install new rings and de-glaze the cylinder walls with a ball hone. There is a definite problem with that second ring -either it has lost tension, or it was installed wrong. Re-installing it will not correct the contact problem. The ring is done. Install and hone on both sides. Be sure to follow installation directions. Rings are both directional AND ring groove specific - top ring in top groove ETC. Check the cylinders for out of round and bore taper. Piston fit must be correct. putting a standard piston in a .010 over bore will not work for long!
There are 2 ways to check piston to bore clearance. 1) install the piston with a brass feeler gage, try and slip it past the piston skirt. 2) using an outside micrometer, measure the OD of the piston skirt in several places. Then, using an inside micrometer, check the bore at the top, center and bottom. Subtract ID from OD and you have clearance value. Look to engine specs for indicated values.
Check the ring faces. Are they square faced with the bore or are they rounded? If rounded, the piston may be rocking excessively in the bore - too much clearance. Check ring end gap clearances. Excess gap will lose compression. Standard rings in an .010 over bore will not seal well. Are the wrist pin to piston and rod clearances correct? Rod bearings in good shape and of correct clearances?
Old 02-11-2017, 04:11:29 PM
MadGutts MadGutts is offline
The compression is low... im going to see about de glazing the cylcinder and reassembling... will get a pressure reading once its back together
possibly a silly question...
Should the rings be sharp on the edge? the 2nd one down is a perfect square edge, but the top one has a champfer so its not a sharp edge?
Old 02-11-2017, 04:32:35 PM
If the rings are properly seated they will be sharp. The top chrome ring has a chrome insert in the face of it you can see it if you look carefully but it too will be sharp. The other rings are slightly tapered top to bottom which is why they can only be installed in one direction. What is the history of the machine has it been apart before to your knowledge. Cheers Dan
Old 02-11-2017, 07:34:55 PM
Motorhead's Avatar
PLEASE, Before you jump ahead and reassemble it again, check the second ring for direction of install. That ring is not right from a wear standpoint. If you push the ring against the bottom of the ring grove OPPOSITE of the GAP, You should see a mark of some kind or TOP or UP that signifies the direction of the ring. ANY mark indicates UP toward the top of the piston.
Back of 1958 5CCK
Contractors model
On trailer owned by
"Ma" Bell.
Old 02-11-2017, 07:59:28 PM
I have no idea if the engine has been apart before, but knowing the UK royal engineers, it will have been at some point!
The 2nd ring does have "TOP" stamped in the top side of it... i did wonder if that was supposed to be the top ring! but the top ring has nothing marked but there is a small dot punched into the top of the ring...
BU the top ring is definitely rounded off!
Old 02-11-2017, 09:47:01 PM
Since you have both pistons out, how do the look of the rings compare to the rings in the cylinder that was not leaking by?
Can you compare how the rings fit in the grooves comparing the two? Maybe the ring grooves in the piston are worn out.
After looking at the picture I do not think you took out both pistons. I do think the top compression ring is worn out because of no sharp edges. It could have worn out the piston ring groove.
Old 02-11-2017, 10:15:24 PM
John Hartman John Hartman is offline
I know nothing about your generator or engine. Reading all this is painful.
You cannot test compression of an engine by manually turning the crankshaft and listening for leakage. You cannot test compression or verify the condition of piston fit or ring condition by pouring fuel on top of the piston.
Put everything back together to the best of your ability, and look for an ignition problem.
The Following 3 Users Say Thank You to John Hartman For This Post:
1 1/2 HP Compression Issue Dylan K Antique Gas Engine Discussion 5 01-01-2016 12:41:19 PM
Mogul 8-16 Compression Release Issue tirediron Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 11-08-2015 01:08:02 PM
Onan 4.0 BGE Spec K Compression masterfabr Onan Generators 2 10-23-2012 11:51:53 PM
Honda GX160 crankshaft swap Timing Issue:Zero compression Subzero Small Air Cooled Gasoline Engines 13 09-04-2012 07:18:41 AM
Military issue MEP-003A Unit Merc300SD Military MEP and Aircraft Gen-Sets 17 11-19-2008 10:46:35 PM
