Onan ATS
this thread has 10 replies and has been viewed 478 times
Old 02-23-2017, 03:28:01 PM
LRomero LRomero is offline
Default Onan ATS
What is a good model Onan ATS to look for? I need a 200amp NEMA 3R (outdoor) unit that is 240v single phase.
Old 02-23-2017, 05:31:32 PM
Billy J Shafer's Avatar
Default Re: Onan ATS
I would look for an LTIII. Very good reliable switch.
Old 03-14-2017, 11:09:48 AM
Is the LT 3 available in service entrance rated? Looking at how I would do my installation I will need service entrance rated.
Here is my current setup:
Overhead service utility comes into my meter panel combo box which is mounted on a pole. That box powers my outside circuits such as sewage aerator, lift pump, and outside plugs. That panel also provides 100A to my shop. Out of the combo box goes to my breaker box in my home.
I think I will ultimately need to revamp the meter panel combo box. If there is a combo box with a ATS and meter socket, that would be ideal!
Old 03-14-2017, 11:20:02 AM
OT III or LT III. Start at 40 amp up to 1000 amp.
Old 03-14-2017, 11:58:09 AM
Correct, but is there a service entrance rating? From what I am reading, SE rating means the ATS has a service-rated disconnect. Non-SE rated switches must have a service-rated disconnect ahead of the switch.
Being I have overhead service mounted on a pole, I am trying to limit the number of boxes on the pole and consolidate as much as possible.
Here is an Onan SE rated ATS, but this is a new switch and not sure how reliable it is. RA200 SE is the service entrance rated model.
http://power.cummins.com/content/res...nsfer-switches
Old 03-14-2017, 01:12:20 PM
I am not sure what the NEC code is in today's world. I would check with the local building inspector. I know the two switches are good reliable,easy to work on switches. Guess I need to get a copy of the NEC
Old 03-14-2017, 02:42:09 PM
I went and checked out the service rating. More confused than ever. From what I read you must have a disconnect in the switch before the main contactors. Guess I will do some more reading.
Old 03-14-2017, 02:55:19 PM
Correct, when the switch is at the service entrance. In my case it will be and a service entrance rated switch will eliminate the requirement of a separate disconnect.
This is what I have, just with more spaces.
Below picture is the best I've found to explain what the NEC requires. This is the reason why I say I will need to revamp my power pole because my meter and distribution panel are a combo unit. My home is connected to the pass through lugs and my outside circuits are connected the the breaker spots like normal. I have no ability to stick a switch between the meter and distribution panel.
Old 03-14-2017, 05:50:11 PM
Gunny Gunny is offline
For the value, I go with a TTI Switch. Yes, any size, shape, amp configuration, single or 3 phase, NEMA3R, service entrance rated.
In my not so humble opinion as good a product as Onan at a better price and far better service support.
Old 03-14-2017, 05:56:26 PM
TTI being Thomson Technology Institute? Is that the same company as Thomson Power Systems?
