Onan Generators Restoring, operating and maintaining vintage Onan generators. |
Onan MDJE Namplate Locationthis thread has 5 replies and has been viewed 353 times
Any body know where is the location of the nameplate on my Onan MDJE generator (manufactured about 1982)? Looked all over the thing and can't find it. Need to find the nameplate because that information seems to be the only way the Onan-Cummins dealer can find information on the injection pump. KiKi injection pump has developed leak where the outlet valves thread into the pump body.
Sponsored Links |
Most of the time. It is on the belt guard up front. Look for six numbers stamped into the block. That is the serial number. Should be around the oil fill tube.
I don't talk to myself. This early in the morning. Why the hell should I talk to you. |
I have 8 or so MDJE/B s and half of them don't have a nameplate anywhere on them. Cheers Dan
It's always something simple. One test is worth a thousand guesses. If some is good and more is better then too much is just enough |
Hey Dan, I would pay a good price for a Kiki injection pump on one of those if you want to part out.
Surprised no one said not to go to a onan Cummins dealer..
You should try a injection shop. I have a stuck Kiki pump that is not damaged, we'll that I know of.. just needs to be unstuck.. it came from a dje |
Found two holes in the flywheel housing where nameplate was supposed to be. Wonder why Onan made this attachment so fragile.
Injector pump won't have to be replaced. I found leak was caused by broken copper seal washer behind delivery valve. Thanks to all who replied and to the forum! |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | F o r u m | Replies | Last Post |
onan 7.5 MDJE needs help | blaise805 | Onan Generators | 35 | 04-20-2014 05:07:10 AM |
Onan MDJE 6-7.5KW Help | Mainshiptom | Onan Generators | 4 | 04-19-2010 05:32:50 PM |
Onan 7.5 MDJE - 3CR Help | LarryGlover | Onan Generators | 11 | 07-19-2007 04:38:12 PM |
Waterloo namplate location | dohouser | Antique Gas Engine Discussion | 8 | 10-12-2006 08:30:16 AM |
Onan MDJE 6-7.5KW Help | Mainshiptom | Onan Generators | 0 | 09-28-2005 05:48:23 AM |
