Onan 4GBE spark problem
this thread has 75 replies and has been viewed 2347 times
Old 03-05-2017, 12:53:27 AM
bbqjoe bbqjoe is offline
Default Onan 4GBE spark problem
I found a few threads here that came real close to the same exact problem, but unfortunately, sometimes people get so excited when their problem is solved, they forget to post what fixed it.
Anyway, I'm sorry if I missed a solution. Onan generator. Model# 4BGEFAZ6100P. Sat for 10 years. Ran when put away.
Mice got to the wiring.
I went through the wiring harnesses and repaired each wire one by one so as not to mix anything up.
I found some burnt and lifted traces on the control board.
No telling why, but quite possibly due to some shorts from the mice.
Went ahead and replaced the board, the fuel pump, filters, oil etc.
This is out of an RV, and has been stand alone forever.
The engine cranks, maybe not getting fuel to the carb, but that's beside the point for right now, I think.
I pulled the plug and did a spark test.
The start switch is new with the board, and comes mounted on it.
The switch is a two or three way rocker, depending on how you see it.
One direction is start, after start it rests in the middle, until rocked the other direction to stop.
There is no spark when cranking, until I let off the start switch, then I see a couple of sparks as the engine quits spinning.
Argh!!!
I very vaguely remember putting a jumper in the remote start coupler for some reason, although I'm not 100% on that, I wasn't very sober back in those days.
Any ideas, work arounds or things I might try?
Thanks,
Joe
Old 03-05-2017, 08:51:52 AM
Kevin K Kevin K is offline
Default Re: Onan 4GBE spark problem
The mice probably got into the generator end, made a nest, and when the engine was cranked the plastic ignition rotor hit the nest and snapped. This is a common cause of a no spark condition in the Emerald series.
Go here to download the manuals:
http://www.twinslan.net/~n0nas/manuals/onan/
965-0528 service
965-0231 Parts
965-0176 Operator
965-0628 Install
Page 6-10 of the service manual describes the procedure for troubleshooting a no spark condition.
Old 03-05-2017, 10:24:01 AM
Small point about your model number, but I think the "Z" is a "2". And the complete serial number might help to get the age and spec, which could be important for determining which wiring diagram is for your set.
I don't know for sure about the 4BGE, but the 6.5NHE had points up to and including spec D. I think later spec models had that electronic ignition stuff.
Pete Stanaitis
Old 03-05-2017, 11:42:33 AM
965-0528 service
965-0231 Parts
965-0176 Operator
965-0628 Install
Thank you for your reply.
The serial # is F990 936 408
I did read about the plastic rotor, but let me ask, if the rotor got snapped off, why would I be getting some spark?
I'm going to go look at the manual, thanks for the link.
---------- Post added at 10:42:33 AM ---------- Previous post was at 10:36:38 AM ----------
Holy banoonies. I went to look for the manual.
Sorry, I'm lost.
Old 03-05-2017, 01:04:24 PM
len k len k is online now
Your gen is spec P, and has electric ignition, with the plastic rotor.
Since it sat for 10 years, first thing to do is disconnect the AC voltage reg VR1. Otherwise if engine starts the dirty slip rings will very likely stress the ~$200 voltage reg and kill it. By disconnecting reg , if engine starts it will stop when you release start button, but you will have protected the $$$ reg. Can then clean slip rings with scotchbrite pad and reconnect the reg.
To test ignition system put a 12V test light across the spark coil primary terminals( low voltage ones), crank engine. Light should blink steadily while cranking if plastic rotor arms are intact and ignition modual is good.
If the plastic rotor is snapped off I believe you get ONE spark when you press the start button and ONE spark when you release it . none in between. Might get same results if it's ignition modual that detects the arm magnet is bad. If you have this pattern of spark pull the ignition modual and looks down the hole to see if plastic rotor arms have broke off. Look at service manual page 6-10
Old 03-05-2017, 01:34:02 PM
I just put a test light on low volt terminals and cranked.
Light comes on steady. No blink.
Old 03-05-2017, 01:45:32 PM
If your test light was ACROSS the coil terminals, then pull the ignition modual and look down the hole to see if the plastic rotor arms have broke off.
Old 03-05-2017, 03:06:40 PM
Module pulled. Rotor presence verified, magnet present on end of arm.
---------- Post added at 02:02:08 PM ---------- Previous post was at 02:00:59 PM ----------
Oh wait, is there more than one arm?
---------- Post added at 02:06:40 PM ---------- Previous post was at 02:02:08 PM ----------
Nuts. Looked closer. Supposed to be 2 arms huh? One is gone.
Old 03-05-2017, 03:09:36 PM
Plastic rotor has 2 arms. Magnet at end of each arm.
Look at item #5 on paper page 25, in parts manual 965-0231.
Rotor is part # 166–0842 ...... Rotor Assembly, Ignition (Includes Rotor and Magnet)
Old 03-05-2017, 04:26:14 PM
Thanks Len. I'm so not looking forward to splitting this thing. But it doesn't look too hard.
Pull carb, and maybe 4 bolts?
Onan Emerald I Genset Spark Problem Saulfun1971 Magnetos, Ignition Coils and Spark Plugs 2 06-13-2016 12:26:10 PM
onan 65nhl genreator spark problem Bob25359 Onan Generators 2 08-03-2014 09:11:14 PM
'94 Onan DKD Spark Arrestor Fitting Problem Pete Miller Onan Generators 1 08-03-2014 07:49:35 PM
Spark Problem Cruiser Onan Generators 16 10-29-2010 07:53:54 PM
Lincwelder 225 Onan CCK spark problem distinguished1 Onan Generators 4 09-11-2008 10:34:52 PM
