Onan 15kw help
this thread has 50 replies and has been viewed 1850 times
Old 03-09-2017, 01:21:39 PM
kosmo101 kosmo101 is offline
Default Onan 15kw help
HI
So purchased an ice cream truck with what I think is a 15kw Genset JB model. Huge unit. I am more familiar with the smaller units so a bit overwhelmed on this. Hoping i could get some help.
So the old owner told me he shut the fuel off. I seee what looks like a clear fuel bowl..assuming thats a fuel filter. Has a brass spinner on bottom. Then looks like a fuel pump then to the carb/fuel bowl with a petcock. Also another spinner on left end of carb. how best to set these?
Fuel bowl seems to drop at times.. assuming the bowl is overloaded. We had a dead battery and tried to jump it and i guess fuel bowl got extra full?
Will get serial # today.
thanks
Old 03-09-2017, 04:16:48 PM
grif grif is offline
Default Re: Onan 15kw help
Full Model and full serial number will get all lthe information you need.
Old 03-09-2017, 05:27:55 PM
Yes, model & ser. numbers, inc. spec. letters at end of model #.
If it is 15 KW, it will likely be a JC not JB. JC is 4 cyl. JB is 2 cylinder.
A picture of what you are talking about would be good. The gasoline JC carb has 2 "adjustment" screws, one on top (low speed adjustment) and one on the bottom of the carb bowl (high speed adjustment). Before you mess with them, download the manual from the link below.
http://www.twinslan.net/~n0nas/manuals/onan/
Try manual #967-0500 for starters. When we know your model # we can direct you to the exact manual.
The Following User Says Thank You to Max Thompson For This Post:
Old 03-09-2017, 09:47:24 PM
its in such a tight spot that i dont know i can get to where the plate is. its in the back of an ice cream truck.
So I replaced battery and she fired up. OMG.. this thing is incredibly loud. I mean to the point that there is no way i could use this truck as is at events. it is just too loud. I checked and looks like a muffler under the truck but the sound you would think there is no muffler. im going to take a video tomorrow and post it. I wonder how loud it should be. it has some funky metal pipe to the muffler. I thought on these JB 15kw units there was exhaust coming out the top on the back of the unit.
Also he has some odd metal tube thing out to a vent from the top of the fresh air side. Trying to figure out what it is. Not very visible in this photo. will see if its for fresh air or some exhaust type of thing....
Old 03-09-2017, 10:03:07 PM
Loudness is a very subjective issue. JCs are louder than today's water cooled, sound attenuated sets by a considerable margin, even with a decent exhaust system. The rating plate probably "was" in the area indicated by the red outline.
Old 03-09-2017, 10:06:37 PM
Wonderful. So obviously this thing is amazingly dirty which i will clean up.
But ive been around many smaller generators from honda to generac and others. Sure i understand this is subjective. I just cannot believe I can use such a loud unit when selling ice cream. ive been around similar types of trucks up north and they never sounded nearly like this one. I will get a video. It is so loud it gives me a headache.. i swear it sounds like there is NO muffler that is how loud.
thanks
Old 03-09-2017, 10:11:37 PM
The exhaust manifold can be turned to point the outlet down, and then all that is needed is a hole in the air shroud for the pipe exit. I have seen some that looked like they beat the hole out with a hammer and cold chisel.
---------- Post added at 08:11:37 PM ---------- Previous post was at 08:08:31 PM ----------
It is entirely possible to use a JC in an ice cream truck. See one member's adventure with same here -https://www.smokstak.com/forum/showthread.php?t=105000
Old 03-09-2017, 10:11:47 PM
going to try to trace out exhaust.. you can see the huge piping on the bottom left of my photo which goes out the floor of the truck and into a muffler. Not sure of the condition but will check it out.
I will take a video of the loudness.
thanks
Old 03-09-2017, 10:17:59 PM
BigBlockChev's Avatar
The majority of the noise is not from the muffler it is from the engine. Don't expect it to get much quieter by just changing the muffler. It is a vacuflow cooling system so you will need to properly connect the discharge on the front of the engine to the outside air and also provide some inlet airflow louvers, don't make them too small. The key to noise reduction is to seal up the generator compartment except for a baffled inlet and outlet. Lining the generator compartment with sound deadening material will help somewhat as well. It is possible to quiet down an aircooled JC but it won't be easy unless you have very good attention to detail, sound will leak out everywhere it can through little holes. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
Old 03-09-2017, 10:47:45 PM
Is there a quieter generator out there.. whether from Onan or some other.
Old 03-09-2017, 11:07:19 PM
Almost certainly, if you have enough money on tap. The first comparable set I found is a water cooled Kubota gasoline engine, 15kW and cost about $13K.
Old 03-09-2017, 11:27:36 PM
Billy J Shafer's Avatar
First thing I see wrong. Is air exhaust has been cut in half. Shoving that much air into a small hole. Can create noise.
Old 03-10-2017, 12:05:44 AM
Not attempting to hijack this thread, but when I was a kid in the 60s, Mr. Softee ice cream trucks came around. You could hear the generator running in the back of the truck. Does anyone know what generator those trucks used?
Old 03-10-2017, 12:17:57 AM
I believe it was the CW.
Old 03-10-2017, 12:41:06 AM
10CW in this one
https://www.smokstak.com/forum/showthread.php?t=91975
I think that is the same truck that he later put a JC in.
Old 03-10-2017, 01:12:14 AM
LRomero LRomero is offline
I want to know why such a big generator on an ice cream truck?!
The Following 2 Users Say Thank You to LRomero For This Post:
Old 03-10-2017, 01:18:38 AM
here is one reason-
https://www.smokstak.com/forum/showp...08&postcount=1
Old 03-10-2017, 01:18:51 AM
Motorhead's Avatar
That cooling air duct looks too small and that can cause overheating. I remember when I installed a 4BGE in my fifth wheel, Onan called for a certain square inch sized opening for outside air to enter the compartment. It was for proper cooling and combustion air. This calculation is different for each generator size. I second that a water cooled set will be MUCH more quiet than the JC.
Friends Don't Let Friends buy GENERAC generators.
Back of 1958 5CCK
Contractors model
On trailer owned by
"Ma" Bell.
Old 03-10-2017, 01:23:24 AM
Originally Posted by Wayne 440 View Post
That's not an ice cream truck I'm used to seeing! That truck to me sound like something that goes around to birthday parties and parks. I'm used to a small van truck or even van in general riding around selling ice cream only. You know the classic ice cream truck music as the truck is driving down the road through the neighborhoods.
Old 03-10-2017, 01:35:24 AM
Vanman Vanman is offline
Yeah, I was thinking the same thing.
But I question the accuracy of that list of *estimated* loads in the other thread. That's an incredible amount of refrigeration if they *actually* take that much power!
Onan 15kw jzbseattle Onan Generators 6 10-19-2012 06:35:05 AM
Onan 15KW JC on LP Cruiser Onan Generators 14 07-01-2012 04:14:43 PM
Onan 15KW Cruiser Onan Generators 8 06-27-2012 04:26:01 PM
Onan 15kw Ed Dina Onan Generators 3 04-23-2003 05:16:00 PM
