Onan 15kw help
this thread has 50 replies and has been viewed 1978 times
Old 03-10-2017, 02:09:26 AM
Motorhead's Avatar
Default Re: Onan 15kw help
The ice cream trucks that used 10-15 kw generators were the ones that sold SOFT SERVE ice cream. I remember them as a kid in the early 60's
The Control panel
and gauges of my
7.5JB
Old 03-10-2017, 08:20:41 AM
stretch67 stretch67 is offline
Turn the VAC U Flow cooling duct down to vent out of the bottom of the truck.
The Car Audio people have some pretty good sound insulating materials.
Attention to detail on sound attenuation is key.
Even a 5 DB reduction is huge difference.
The JC is a great unit, and with proper care will last long time.
Old 03-10-2017, 08:22:24 AM
My first question is; what does it have for a muffler now?
Not relevant to the noise, but I wonder if there is a flex section in the piping to the manifold.
As was stated earlier, a JC is relatively noisy, but in your situation with proper insulation and a "good" (good can = expensive) muffler they can be quieted considerably.
Second question; how much generator do you need? What are your electrical loads?
Old 03-10-2017, 09:31:17 AM
kosmo101 kosmo101 is offline
i actually thought it was overkill too. The ones up north have 18 or 22kw units. amazingly huge. For one soft serve machine 208-230v but two separate cords. The machines are basically two in one. So double the power needs. recommended on three phase to have 19amp and 17 amp . I may switch this machine to another I have which seems to need less power.
Then we have a shaved ice machine..not sure of the power needs on that. Ac unit sucks a ton of power. One light, one fridge, small freezer and shake machine.
Im going to test this weekend to see what my needs really are. More power cant hurt but there has to be a money aspect to this as im not looking to spend an unlimited amount of money.
I will trace out from the manifold to the end pipe to see what is going on. i cant tell just yet if its the engine itself being loud or the muffler/exhaust is an issue. Again it sure sounds like there is no muffler on it..that loud. it sounds like my 6500 unit with no muffler but much louder. Guess it would help if i had another one to judge against.
I assume it is the normal/stock muffler. Is there one i could swap to in order to try to get it quieter.
with the unit in the back of a truck, vents on both sides and the top on one side, how would insulating really help? we can pull the rear door down to keep the sound a bit muffled but when i tried that it sure was still amazingly loud. Maybe even worse as it echoed inside this area? Will snap photos...
thanks!
kevin
So in looking at similar units.. it appears the exhaust manifold is out of the back of the unit but shoots up...is that correct? Meaning venting vertically past the top of the unit? Wondering how mine ended up under the truck.. very tough to get in this compartment to see behind the unit.
Old 03-10-2017, 09:41:34 AM
Originally Posted by BigBlockChev View Post
The majority of the noise is not from the muffler it is from the engine. Don't expect it to get much quieter by just changing the muffler. It is a vacuflow cooling system so you will need to properly connect the discharge on the front of the engine to the outside air and also provide some inlet airflow louvers, don't make them too small. The key to noise reduction is to seal up the generator compartment except for a baffled inlet and outlet. Lining the generator compartment with sound deadening material will help somewhat as well. It is possible to quiet down an aircooled JC but it won't be easy unless you have very good attention to detail, sound will leak out everywhere it can through little holes. Cheers Dan
The above advice is how it is done. All vents, openings, etc. must be baffled, i.e. no direct line of sight to the outside. Single layer sheet metal portions of the enclosure can "retransmit" or reverberate sound, apply sound deadening material to same. Doors and covers should seal tightly. If possible direct vents away from occupied areas, straight up is a common choice in stationary applications.
Originally Posted by kosmo101 View Post
...So in looking at similar units.. it appears the exhaust manifold is out of the back of the unit but shoots up...is that correct? Meaning venting vertically past the top of the unit? Wondering how mine ended up under the truck.. very tough to get in this compartment to see behind the unit.
I covered that possibility earlier--
Originally Posted by Wayne 440 View Post
The exhaust manifold can be turned to point the outlet down, and then all that is needed is a hole in the air shroud for the pipe exit. I have seen some that looked like they beat the hole out with a hammer and cold chisel.
Old 03-10-2017, 11:32:00 AM
From the equipment you listed, the starting power requirements could be quite high.
There was not a "stock" muffler per sae. Mufflers were an option and different ones available for different requirements. Most anything of the proper inlet & outlet size (1 1/2" ips inlet on most), that you can fit under the truck will work.
You may as well start devising a plan to remove the set from the truck. Sooner or later it will have to come out. With all lines and exhaust disconnected (the exhaust will likely have to be sawn off where it goes through the floor) it can likely be slid out onto a platform of concrete blocks & a piece of plywood. A sheet of 1/8" steel sheet on top of the plywood would make it slide much easier. You could possibly raise it up and get some 3/8" rod or 1/2" pipe under the mounting rails and roll it out. Probably in the #700 neighborhood. If you have access to a "lift table" or motor cycle lift it could be pretty easy to remove.
Old 03-10-2017, 11:38:31 AM
Why do you say to start thinking of it coming out? Maintenance? just curious your thoughts.
Old 03-10-2017, 12:16:09 PM
Maintenance yes.
The starter is mounted on the back side. It will be very difficult to adjust the rocker arms or get inside the control box with the limited space over the unit.
If you do any insulating (sound deadening) to the compartment, you will have to get to the back side.
If I were going to rely on this set to run my business and keep several $ worth of product from being lost, I would pull it out and give it a through going through Before I put the truck into service.
Removing it (with the right equipment) would not be a big job. Though I may not be a very good judge of the degree of difficulty. Having 9 JCs floating around the place, I am pretty adapt at moving them around and up & down.
The Following 2 Users Say Thank You to Max Thompson For This Post:
  #29
Old 03-10-2017, 12:20:10 PM
understood. as you mention, that is why i am considering maybe pulling it out as well. if it doesnt work when we get to an event, im dead. im used to smaller honda units so no idea how reliable these are. checking out the quiet diesels and also a yanmar unit. A bit out of my element on the reliability of such makes.
I was going to ask to borrow a neighboring shops forklift to remove or maybe use a engine hoist. I also need to possibly remove the soft serve machine from inside.. that should be fun.
happen to have a good unit for sale ? figured since you had nine units.. it may be worthwhile to ask!
Old 03-10-2017, 12:54:47 PM
I was going to ask to borrow a neighboring shops forklift to remove or maybe use a engine hoist. .
When properly maintained, the J series are very reliable and will outlast most of us here.
A fork lift should make short work of removing the set from the truck.
Not saying they could not be bought, but none advertised for sale (we do not buy and sell on this board).
You may have a great generator right now, give it a chance. If I did not think they were great sets, I would not bother accumulating them.
Onan 15kw jzbseattle Onan Generators 6 10-19-2012 06:35:05 AM
Onan 15KW JC on LP Cruiser Onan Generators 14 07-01-2012 04:14:43 PM
Onan 15KW Cruiser Onan Generators 8 06-27-2012 04:26:01 PM
Onan 15kw Ed Dina Onan Generators 3 04-23-2003 05:16:00 PM
