Onan Enclosure Thoughts - 6.5NH
this thread has 27 replies and has been viewed 1021 times
Old 03-13-2017, 01:07:12 AM
len k len k is offline
Default Re: Enclosure Thoughts - 6.5NH
Check if exposed Styrofoam. would need to be at least covered by metal foil. Maybe more , I don't know fire code
Old 03-13-2017, 01:36:18 AM
Vanman Vanman is offline
As said it was foil faced. Obviously you would still need a thimble for the exhaust, but so would you for wood. I can't see it being a problem, so long as no exhaust components were close to it. (Radiant heat).
Old 03-13-2017, 07:49:23 AM
DMeed DMeed is offline
The ad mentions foil faced poly isocyanurate foam which is a bit different animal that styrofoam. Maybe (emphasize _maybe_) fire retardant or fire resistant - check on it. I know solar panel construction calls for that foam because it stands up to the high temperatures in solar panels where the extruded stuff melts.
David m
Old 03-13-2017, 08:28:25 AM
PopsGarage PopsGarage is offline
Nice enclosure I cant build one for that price.
Bob
Old 03-13-2017, 11:59:44 AM
willie1959 willie1959 is offline
Default Re: Onan Enclosure Thoughts - 6.5NH
Use drywall for sound two layers cheap works great. A 2x4 frame wall with 3/4 plywood exterior , 3 1/2 fiberglass batt insulation and two layers of drywall is good for 45 db sound level reduction. I use a sound meter less than 50db at 10 feet from generator
only thing better are cement blocks for sound
for exhaust 15 foot stack up
The Following User Says Thank You to willie1959 For This Post:
Old 03-13-2017, 12:32:14 PM
How about a double stud frame wall, with the inner and outer studs staggered with insulation between all of the studs. Double 5/8" drywall on the inside, the 3/4 ply on the outside. Then the vibration from the inner wall cannot couple to the outer wall.
Old 03-13-2017, 01:06:44 PM
that's the best just trying to keep costs down
Old 03-13-2017, 02:12:36 PM
Those are back flow encloses.
I would be amazed if you could buy one from the manufacture for the $200 price in the ad. Would have to assume someone is selling surplus from a job.
There would likely be no fire retardant material in it. It is designed for water piping inside only.
Old 03-13-2017, 02:20:39 PM
Kevin K Kevin K is offline
While 3/4" PT plywood, double stud walls, 3.5" fiberglass insulation, and two layers of sheetrock are great ideas for a 10x10 shed, they are just not doable on a doghouse style generator house. The problem of access to the generator for maintenance makes these construction methods impractical. Well... I guess I could use a front end loader to lift the entire house away from the generator and base, but I don't consider that easy access.
If you could indeed purchase the aluminum enclosure for $200, I would jump on it.
Old 03-13-2017, 02:34:32 PM
LRomero LRomero is offline
I agree, the aluminum enclosure for $200 is a steal. I would jump on that in a heartbeat and wish I could find something like that in my area at that price.
Onan 6.5 nh in its new portable enclosure yellowlister Onan Generators 16 02-09-2015 03:12:43 AM
Onan 5.0 CCK 3CR/8457R Enclosure; Dale Russell Onan Generators 3 09-23-2014 08:02:00 PM
Onan MAJB enclosure Jeff Klein Onan Generators 0 06-06-2013 02:03:29 AM
Onan Weatherproof Enclosure country bumpkin Onan Generators 10 09-22-2010 10:30:37 PM
Onan 12.0 DJC Enclosure (Noisy!) Steve Dawkins Onan Generators 37 03-17-2005 05:56:07 AM
