Onan 10.0CCKAJ want to convert to electric start
this thread has 32 replies and has been viewed 945 times
Old 03-12-2017, 08:11:39 PM
DrCharles DrCharles is offline
Question Onan 10.0CCKAJ want to convert to electric start
My clean, low-hours 10.0 CCKAJ (pull-start) is a real bear to pull, especially in cold weather. So I'm interested in adding a starter motor to save my shoulders and arms. (Recharging the battery would be simple, just plug a battery charger into one of the 120v outlets on the box!)
There are a variety of operator and parts manuals available which are usually "close enough" but I never have found the exact one for this unit.
It seems that CCKA starters (and the bracket that mounts them to the base pan) are readily available. But there isn't any obvious place for an electric starter to go, and I didn't have time to remove the pull starter and fan housing to see where an electric starter might attach.
I'm beginning to think this particular model can't be retrofitted with an electric starter at all! Any ideas besides "sell it and get one with electric start"
thanks
Charles
Old 03-12-2017, 08:38:54 PM
Default Re: Onan 10.0CCKAJ want to convert to electric start
If you "don't have time" to look inside the flywheel housing, you probably won't have the time to implement my idea. But if you get tired enough of pulling on it, consider a generator/starter unit as found on old Cub Cadet garden tractors. You could probably fit a V belt around the existing rope pulley well enough to crank it up. I have seen this retrofitted to many engines with a simple lever which tensions the belt and also depresses an old type starter button.
Old 03-12-2017, 08:39:58 PM
Vanman Vanman is offline
Being a revolving armature generator, you might get away with applying 12 volts directly to the commutator brushes. You would not have the benefit of the series winding that exciter cranked sets have, but I have heard of others doing this with success. The worst case would be that you need to help it over the first compression stroke, but after that it ought to spin over just fine like that.
Keith
Old 03-12-2017, 08:54:33 PM
That's rather harsh... it's been a busy weekend. I didn't mean that I would never have the time!
Good idea, thanks... but the rope sheave is inside the sheet metal housing that is required to direct cooling air across the cylinder heads. Also the generator is mounted on the Onan "wheelbarrow" cart and that kind of rig would be hard to fit and remain portable.
Well, worst case is that I fry a perfectly good 10 kw generator head
I'll do some searching for this. That 16 hp engine takes a fair bit of torque to turn it over compression...
Old 03-12-2017, 09:19:45 PM
Hmm, maybe you could make a fixture that engages the notches in the rope pulley (or maybe the flywheel nut) and fits in a 1/2" cordless drill. Along the lines of an Indy car starter.
Old 03-12-2017, 09:31:04 PM
Having cranked one over with a drill, that's pretty harsh. Even a 1/2 drill is working it's rump off and you're hanging on for dear life.
In theory, if you had power for a drill, you wouldn't need the gen. I can say a dewalt 18v cordless drill does NOT like this kind of abuse. It's getting very hot within seconds.
The standard starter bolts to the oil pan underneath the right hand cylinder head, and engages teeth on the flywheel. If you have flywheel teeth and/or holes in the pan, who knows. I think at most you would need a toothy flywheel, a bolty oil pan, a cranky starter, and the fan shroud to clear it all.
Old 03-12-2017, 09:43:23 PM
My 1/2" drill motor won't do me much good, since the only way I'd be firing up this generator is if the power's out!
I could swear the flywheel is already toothy but will need to look again. As I get older I start to experience CRS
The illustrations on the CCK manual for units with a starter do show a fan shroud that has a circular relief in the lower right corner, now that you mention it... might be hard to find one of those, although I could do some sheet metal work if needed.
Old 03-12-2017, 10:08:51 PM
Dan H Dan H is offline
I own a 1957 welder with a pull start cck. This machine was always a real bear to start even 30 years ago. The first step to improve it was to disconnect the points from the mag under the flywheel and hook the points up to a 12 volt battery and rather than using the onan coil, hooked up 2 automotive 12 volt coils, 1 to each cly. Started a lot nicer because now it had a hotter spark right away without spinning it over as fast. Fast forward another 25 years, and older yet. Rigged up a spark module from a ford pu, 1992 and a double coil from some kind of car. The points worked as a trigger for the module. All I had to do was disconnect the condensor. Now on a cold day, turn on the fuel, prime the fuel pump, turn it over slowly twice with the power off, bring it up to the compression stroke, turn on 12 volt power, and snap the rope and there she goes. I have the parts to convert it to electric start someday,just no need yet. Dan
Old 03-12-2017, 10:24:41 PM
David C David C is offline
If you were closer to Texas, I have a generator end off of a 10.0CCKB that I would make you a deal on. I used the engine on a 5.0CCK that had an engine that had water damage.
David C.
Old 03-12-2017, 10:45:17 PM
Is that an exciter-start type? What's it weigh?
I have a FedEx shipping account and can often get decent rates...
Onan JB Electric Start on Natural Gas Leon N. Onan Generators 33 09-26-2015 10:21:58 PM
I think I got the wrong manifold for my Onan 10.0CCKAJ/1E DrCharles Onan Generators 15 11-23-2012 06:11:00 PM
Convert an Onan diesel MDJE to electric fuel pump? Boydster Onan Generators 23 06-28-2012 09:54:50 PM
onan 5cw-3r 1b electric start wkobe88822 Onan Generators 1 03-12-2012 10:37:54 PM
Wisconsin TFD--convert to electric start? albngore Antique Gas Engine Discussion 1 01-23-2006 10:48:49 PM
