FAIL 1st power outage with Onan 45 OEM-15r 9296C and OTOCA 5566643 Spec A
this thread has 41 replies and has been viewed 1927 times
Old 03-13-2017, 06:30:00 PM
gjinc gjinc is offline
Default FAIL 1st power outage with Onan 45 OEM-15r 9296C and OTOCA 5566643 Spec A
HI,
Last Thursday I had my first power outage with my generator. Everything worked good for 2 hours then fail...
Engine went to 3000rpm, voltage and Hz was very high. No over freq light, no over speed light, no shut down. With all the monitoring in the transfer switch, I thought it would disconnect when out of limits, but it only showed out of limits and showed NOT Available, did not disconnect or shut down the generator.
I figured out pretty quick that the electronic speed control failed. After a couple of hours of troubleshooting I found a c clip on the actuator out of a groove, snapped that back in. I reset it to 1851 rpm's but had about 150 rpm drop when the heat pump would start. So now with a new speed control box I'm waiting for the next outage.
I need to know if the transfer switch, OTOCA 5566643 spec A is suppose to drop the connection or shut down the generator when it is out of limits?
I also thought the engine control 332-2595 F would also shut the generator down for over freq or over speed?
Any suggestions?
Old 03-13-2017, 06:47:40 PM
Billy J Shafer's Avatar
Default Re: FAIL 1st power outage with Onan 45 OEM-15r 9296C and OTOCA 5566643 Spec A
The transfer switch will not shut down the generator until all timers are complete. It will look for the highest source of voltage then switch to that source. Over speed control should have shut the system down.
The Following 2 Users Say Thank You to Billy J Shafer For This Post:
Old 03-13-2017, 06:53:44 PM
Onan Dan's Avatar
Onan Dan Onan Dan is offline
Maybe you can answer a question my brother has a heat pump for his home heat and ac what amps would it need to operate I am not sure of btu or anything. thanks
Old 03-13-2017, 07:08:11 PM
HI, my heat pump has a "soft start" installed. It stops flickering lights when it turns on and helps generators when connected. Start with looking at what size circuit breaker the heat pump is on.
---------- Post added at 07:08:11 PM ---------- Previous post was at 07:05:43 PM ----------
So all the monitoring is only for connecting the power...darn
I was hoping for a easy answer, how is the engine control suppose to shut the generator down?
The Following User Says Thank You to gjinc For This Post:
Old 03-13-2017, 07:12:30 PM
Is this the set that you retrofitted an aftermarket electronic governor to?
If so, did you verify operation of the overspeed function after installing same?
Billy- is overspeed an option on the EM as it is on the JC sets???
Old 03-13-2017, 07:31:59 PM
Yes, I bought the speed sensor and actuator, the electronic speed control was on the unit. It tested great so I didn't replace it.
With the new speed control I put on today, I do see a difference, a lot more sensitive.
I never oversped the unit , I never over temp it either.
---------- Post added at 07:31:59 PM ---------- Previous post was at 07:19:32 PM ----------
I will clarify, the controller was giving to me by the guy I got the generator from.
Old 03-13-2017, 07:34:08 PM
IIRC, the overspeed switch is in the generator end bell and provides a ground to the control board on overspeed. The switch could be stuck or dirty, wire broken, etc.
The Following 6 Users Say Thank You to Wayne 440 For This Post:
Old 03-13-2017, 07:41:55 PM
The transfer switch will call for a start on low or loss of power. When power returns it will go into time delay to normal. Then it will transfer to normal power. If it sees a dip in normal power. It will transfer back to emergency. When normal power returns and is good for the time delay. It will transfer back to normal and go into time delay stop. If normal power drops. It will go back through the system again.
The engine control will shut off the system. When it receives a shutdown fault or the normal shutdown command.
---------- Post added at 06:41:55 PM ---------- Previous post was at 06:38:43 PM ----------
I have never seen an overspeed as an option on the large units. On the early ones it was the same as the JC units. Later ones had the option of an overspeed board or the JC type.
Old 03-13-2017, 08:26:12 PM
Motorhead's Avatar
I wonder if a stand alone over-speed system could be built or adapted that would kill the engine if the RPM exceeded the set limit. Kind of like a "Murphy" switch or a Tachometer with a rev limiter.
The Control panel
and gauges of my
7.5JB
Old 03-13-2017, 09:02:33 PM
I think at one time Murphy did build one. May still do.
Onan 45 OEM-15r and OTOCA 5566643 Spec A 2 or 3 Wire Output? gjinc Onan Generators 6 06-23-2016 10:08:35 AM
Onan OTOCA 5566643 spec A amp transfer switch Questions gjinc Onan Generators 8 03-06-2016 10:04:24 PM
So California Power Outage lijobi Onan Generators 29 09-11-2011 06:02:16 PM
I'm ready for a power outage! Gunny Onan Generators 26 12-15-2010 09:01:56 AM
