Onan CCW 5.0KW - constant load required?
this thread has 3 replies and has been viewed 319 times
Old 03-14-2017, 10:49:08 PM
Riley Riley is offline
Default Onan CCW 5.0KW - constant load required?
Hi guys -
I've got a sweet Onan CCW 5.0KW (pic attached I hope).
I owe thanks to Dan (BigBlockChev) for help in locating this baby.
Anyway, as I finally get close to installing this at my off-grid cabin to back-up my solar power system, the Solar Power guy asked the following question:
"just wanted to make sure that the generator doesn’t require a constant load to “keep it warm”. We have seen Onan’s that draw down the battery because they need a constant draw to run a heater."
I can't imagine how a constant load would be required for a generator as that would never really occur in practice.
He just clarified this is for a block heater on the generator. I don't think I have one but thought I'd come here and ask the experts.
Do some Onan models have a block heater?
Old 03-14-2017, 11:00:31 PM
Dale Russell Dale Russell is offline
Default Re: Onan CCW 5.0KW - constant load required?
Diesel unit use a block heater sometimes use a heater in cold climate's to keep them warm since they fire by heat of Combustion. I think your's is Gas.
Old 03-14-2017, 11:06:11 PM
Yes, mine is a propane fired GenSet. Makes sense some diesels would want a block heater.
Old 03-14-2017, 11:21:38 PM
Billy J Shafer's Avatar
Originally Posted by Riley View Post
Hi guys -
The water cooled units had block heaters. The ONAN diesels J type really needed them.That does not use a block heater. They did have oil base heaters. Pretty much useless. I have started ones like that at 15 degrees. Never had a problem really.
1989 onan 6.5kw mcck marine generator, back fire thru carb & constant govenor search newder Onan Generators 8 07-31-2014 04:02:52 PM
Onan 4.0 CCK-1R / 8793J remote start, constant run problem zombiejuice Onan Generators 9 07-19-2013 09:12:18 PM
Onan 3MAJB starts, runs no load/partial load, BUT? dawghouse3 Onan Generators 15 06-09-2009 04:19:43 PM
Onan CCK help required Ben Clarke Onan Generators 14 06-27-2007 08:38:51 AM
Old red Onan generator help required. PhilipP Onan Generators 8 07-21-2005 03:06:46 PM
