Onan 4.0 BGE electronic conversion
this thread has 16 replies and has been viewed 517 times
Old 03-15-2017, 06:51:43 PM
deno deno is offline
Default Onan 4.0 BGE electronic conversion
Here is the plate: https://do not use shortened links/photos/tqiqQuEdakc5U1sh6
I googled site:www.smokstak.com 4.0 BGE and read the threads available. They all talk about using an ONAN electronic ignition part which is no longer available. I can't be sure where I read it, using generic parts around $50 available at Carquest or another retailer, to convert the distributorless two-cylinder design to electronic ignition.
Thanks!
Old 03-15-2017, 09:03:15 PM
len k len k is online now
Default Re: Onan 4.0 BGE electronic conversion
Link doesn't work.
Are you talking about the electronic ignition modual that sense magnets on a plastic rotor arm. Or electronics that use the points , but reduce current thru them.
Old 03-15-2017, 10:24:14 PM
I guess the site doesn't allow Google Photo links. Wtf?
---------- Post added at 08:23:07 PM ---------- Previous post was at 08:21:32 PM ----------
---------- Post added at 08:24:14 PM ---------- Previous post was at 08:23:07 PM ----------
This is stupid. How the hell are you supposed to post images from the single most widespread and common image solution on the net?
Old 03-15-2017, 10:40:47 PM
MAybe copy the http address from top of the browzer and paste it here?
Sometimes sites or bowzer display shorten the address so it's easier to read ( but it doesn't contain the full link that computer needs)
Old 03-15-2017, 10:49:02 PM
I opened up the Google Photos app on my phone. And then I found the photo and choose share - get link, and it got copied to my clipboard and I pasted it into the forum.
Old 03-16-2017, 01:26:25 AM
I don't know cell phones, got a landline. Maybe someone else knows.
Could just describe it to us.
Old 03-16-2017, 12:33:55 PM
preskitaz preskitaz is offline
Originally Posted by deno View Post
Here is the plate: https://do not use shortened links/p...qQuEdakc5U1sh6
Thanks!
This what you are talking about?
https://www.smokstak.com/forum/showp...7&postcount=43
The Following User Says Thank You to preskitaz For This Post:
Old 03-16-2017, 02:32:30 PM
Here's a list of some methods to use car and other electronic moduals.
https://www.smokstak.com/forum/showt...90#post1371090
Old 03-16-2017, 06:31:45 PM
Here, I had to download the images, then re-upload them for the forum to take them.
ID:	277664   Click image for larger version
Old 03-16-2017, 06:36:24 PM
Yes. And now I asked him for the parts list.
Also, in a document, the EI gives a precise timing of 21 degrees, whereas the points are claimed to give 21 on one cylinder, and 23 on the other. Having the EI fixes this issue. Is that true if the points are used as a trigger as shown in the thread you linked?
Onan 4.0CCK Electronic Governor and NG Conversion zuhnc Onan Generators 16 07-13-2016 02:50:30 PM
JC electronic ignition conversion nothingbutdarts Onan Generators 2 06-20-2015 02:13:47 PM
Onan electronic conversion problem wbmiller3 Onan Generators 4 11-08-2012 01:46:58 PM
Onan electronic Ignition conversion ? NF BF GHanners Onan Generators 2 09-19-2009 07:40:49 AM
4.0 CCK Electronic conversion questions Ben Cowan Onan Generators 7 07-01-2009 12:01:18 AM
