Engine ran without cover on Onan 15JC
this thread has 24 replies and has been viewed 847 times
Old 03-18-2017, 11:57:21 AM
bowser22 bowser22 is offline
Default Engine ran without cover on Onan 15JC
hi guys been a while. Recently had a power outage with all the wind we got on the east coast. I started the 15jc up and let her purr to get to warming temp, somehow the engine cover loosened its way off. Luckily I was in the garage at time moving things into cold storage and noticed the engine rpms take a cut after about 4 minutes of running. I quickly shut the unit off, reinstalled the cover and started her back up. It seems to be working great but just wonder how long these can really run before damage occurs? It was not under any load, I hadn't gotten around to flip the main breaker.
Old 03-18-2017, 12:05:05 PM
Vanman Vanman is offline
Default Re: Engine ran without cover on 15JC
If the RPM dropped without a load, sounds like it was thinking about seizing up. Good thing you caught it right away.
From what I understand, with overheating, a few things might happen. For one, the rings can loose their temper, or expand until their gaps close, and then break and / or gall the cylinder. Or the piston can expand and gall the cylinder. In severe cases the piston can be broken.
In your case, it sounds like maybe it was just starting to get tight when you caught it.
In all cases except those with obvious damage, I'd just pay attention to how it runs once cooling is restored, monitoring performance and oil consumption. I'd guess that in most cases they'll end up being fine.
Keith
Old 03-18-2017, 12:13:28 PM
len k len k is online now
Since it was starting to drop rpm things were starting to get tight, so damage was beginning. But you may have caught it in time. Could pull the heads and see what cylinder walls look like.
Old 03-18-2017, 12:18:04 PM
I might get a borescope and put it down the plug hole, see what things look like.
The Following User Says Thank You to bowser22 For This Post:
Old 03-18-2017, 12:19:45 PM
IF it were mine, I would secure all the covers well, check the lube oil level and run long enough to get the oil hot. Then change oil and filter, and run it loaded for a while.
If no unusual oil consumption or noises, I would say " what good luck..." and not worry about it.
Old 03-18-2017, 01:11:49 PM
JohnnyC JohnnyC is offline
Change your oil and filter now.
JohnnyC
New Jersey
---------- Post added at 01:11:49 PM ---------- Previous post was at 12:45:49 PM ----------
JohnnyC
New Jersey
In addition, I would not go through the extreme of pulling off heads if the JC seems to run ok otherwise you will be spending lots of time and costs for head gaskets, push rod tube O-rings, readjusting valves, yada, yada, yada.... What I would do aside from an oil and filter change is a compression test. A compression test should take no more than 5 minutes a cylinder and is simple. If all seems up to spec and after an oil change, I would just watch for any abnormailites on your next generator exercise under load such as excessive oil consumption.
JohnnyC
New Jersey
Old 03-18-2017, 01:13:48 PM
I was just thinking if you saw minor damage to cylinder, you might hone or sandpaper it a little. Hate to spend real money.
Old 03-18-2017, 01:16:15 PM
Default Re: Engine ran without cover on Onan 15JC
I did pull the dip stick when this happened and it wasn't excessively hot, the oil didn't seem to be burning. It was also around 30 degrees F outside. This engine had milkshake oil in it, which I already dumped out in favor of some cheap stuff. I guess I'll put some of the rotella I've been saving for it.
Old 03-18-2017, 01:24:08 PM
Does not matter if you believe the oil was not too hot or cold in the pan. IF the engine overheated causing rpms to drop with the *assumption* it was about to seize, change the oil and filter now. There could be microscopic metal debris in the oil from the result of the possible overheating in the cylinder / piston area of the motor.
Do a compression test too as I already mentioned. If compression is low, there may be damage to the rings and /or head gasket as well as head warpage then take it from there. Again, do the easy simple tests first before ripping the entire JC apart without really knowing what is good and bad.
JohnnyC
New Jersey
JohnnyC
New Jersey
Old 03-18-2017, 01:54:22 PM
Even if the compression is low immediately following the incident, it is also possible that it will just wear in again. Changing the oil and filter is an excellent plan. Beyond that I would do absolutely nothing besides observation. Run it.
Keith
Onan 15JC air cooled engine timing cjgpokny Onan Generators 15 05-02-2014 08:21:14 AM
Help me out with an Onan 15JC wilson Ross Onan Generators 21 08-29-2012 12:00:29 PM
Onan 15JC Stuck engine ?? John10 Onan Generators 2 10-25-2009 06:50:44 PM
Possible frozen Onan engine on a 15JC Gen Set John10 Onan Generators 4 10-03-2009 03:29:30 PM
15JC top cover crbearden Onan Generators 2 12-28-2007 05:07:37 PM
