Engine ran without cover on Onan 15JC
this thread has 24 replies and has been viewed 823 times
Old 03-18-2017, 01:59:28 PM
Kevin K Kevin K is offline
Default Re: Engine ran without cover on Onan 15JC
How much speed did it drop? I know it is difficult to estimate, but did it sound like the engine was lugging down? Was it really 4 minutes, or a lot longer? When cranking to restart it, did it seem like it was cranking slowly?
If you have a bore scope, check the cylinders with it. You could try cranking it by hand with the spark plugs removed to check for any additional drag. A compression test is in order, and a leak down test as well.
I would not tear it down just yet. An oil change would be a good idea,.
It was started from cold (30 degrees) and ran four minutes with no load. Even with the cover missing it would have had some cooling. I'm not sure it would overheat in four minutes under those conditions.
Could it be the engine speed change you thought you heard was really a change in engine sound as the choke came off and the mixture changed?
The Following 2 Users Say Thank You to Kevin K For This Post:
Old 03-18-2017, 02:08:58 PM
Your idea of a borescope is a good one. Do as others recommend - change the oil and filter. You could go as far as examining the oil that came out for debris or aluminum flakes (start with a clean drain pan) and peel the old filter apart and look for debris in it. With fresh oil and filter, run it for an hour or more under a pretty good load and listen for any new noises, particularly piston slap. Then drain the oil again and look for any debris that might come from a piston that started to seize and is wearing back in. Also look for oiling on the spark plug. And don't worry about it too much. Years ago when I was building performance British motorcycles I would occasionally have one try to seize right after rebuild, would back off on it for a bit, and it would be just fine after that. This was back when I had the belief that the best way to break in an engine is to run it hard right from the start. I've even pulled a few apart that went many trouble-free miles, only to discover light seize marks on the pistons.
Old 03-18-2017, 03:32:16 PM
bowser22 bowser22 is offline
It only dropped a couple hundred rpm, then I thought hmm thats weird. It was still even within range on the frequency meter. It wasn't lugging or anything. Then I reinstalled the cover and started it, started normal, not labored. It was really only about 4 minutes.
Old 03-18-2017, 04:27:10 PM
I will take a chance and try a different thought.
If this is a gasoline set, maybe the choke just finished opening up all the way and made the engine sound different. At 30 degrees for 4 minutes with no load, damage is very unlikely. Or maybe as the cover was falling off, it caught the throttle linkage and pulled it down a little.
It can not hurt anything to change the oil and filter and keep an eye on it for an extended loaded run. But at 30 degrees the shutters on my JC will not open for at least 10 - 15 minutes.
The Following 3 Users Say Thank You to Max Thompson For This Post:
Old 03-18-2017, 04:31:30 PM
Originally Posted by Max Thompson View Post
...maybe as the cover was falling off, it caught the throttle linkage and pulled it down a little...
Good possibility.
...It can not hurt anything to change the oil and filter and keep an eye on it for an extended loaded run...
That was my thinking, oil and a filter is cheap compared to most engine work.
Old 03-18-2017, 04:44:42 PM
Billy J Shafer's Avatar
I think you may have just been hearing things. I have gone to JCs to work on them. To find the cooling door off and on the floor. I have a hard time believing a short time in that temp. Doing any damage. They can ice up in the carb,if conditions are just right. Ice breaks off and effects the running. Choke delay on opening can also cause a problem. I wouldn't worry about.
The Following 2 Users Say Thank You to Billy J Shafer For This Post:
Old 03-18-2017, 05:49:09 PM
Gunny Gunny is offline
Going to agree with Billy on this. As it was not under load, doubt it was hot enough t do any damage, especially in under 5 minutes. I've seen them run for 20 minutes with the cover off for weeks at a time for exercise with no apparent damage.
Think all is good.
The Following 2 Users Say Thank You to Gunny For This Post:
Old 03-18-2017, 06:09:42 PM
geezer88 geezer88 is offline
I'll go with Billy and Gunny on this one. Without the covers on, you've got a motorcycle engine. From a cold start, no load, four minutes wouldn't seem that bad. I bet it's fine.
tom
Old 03-18-2017, 06:42:56 PM
Troll's Avatar
Troll Troll is offline
I think it's junk and to alleviate your pain should be put on a truck headed my way in an expeditious manner.....
I don't need to repeat good advice but don't think there is anything to worry about. I'm willing to take the chance and make use of it however.....
Old 03-18-2017, 07:11:30 PM
Mike57 Mike57 is offline
I have several indicator gauges on my JC, including CHT and EGT. I've run mine without covers up to 5 minutes, at a lot higher ambient(80) than what you were at. It took 5 minutes for the CHT to hit 325 and I shut it down. If you were truly only at 4 minutes, you're probably fine.
Onan 15JC air cooled engine timing cjgpokny Onan Generators 15 05-02-2014 08:21:14 AM
Help me out with an Onan 15JC wilson Ross Onan Generators 21 08-29-2012 12:00:29 PM
Onan 15JC Stuck engine ?? John10 Onan Generators 2 10-25-2009 06:50:44 PM
Possible frozen Onan engine on a 15JC Gen Set John10 Onan Generators 4 10-03-2009 03:29:30 PM
15JC top cover crbearden Onan Generators 2 12-28-2007 05:07:37 PM
