Onan 4.0 BFA on a Versalift Boom Lift
this thread has 25 replies and has been viewed 2055 times
Old 03-18-2017, 07:26:58 PM
Dennis112885 Dennis112885 is offline
Default Onan 4.0 BFA on a Versalift Boom Lift
Hi everyone. I'm new to the forum and I could use some help. I purchased a Versalift tow-behind boom lift, and it's powered by an Onan model 4.0 BFA-3CR/22353C, SN:A853869113. Here are some pictures:
The Onan is original to the lift. Looks like there is a shaft and coupling bolted to the cooling fan, coupled to a hydraulic pump to pressure up the hydraulic system.
I purchased the lift for $600. I didn't know anything about Onan Generators when I bought the lift, and I figured I could easily bolt on a new gas engine to power the hydraulic system. After doing research into these generators, I quickly realized that I'd like to keep what I have and make it work.
So, first thing on the agenda was to get the thing to turn over and see if I have spark. I quickly noticed that the control panel had been bastardized. There were several splices and the fuses were removed and replaced with switches. I couldn't get the thing to turn over. Here's the condition of the control box when I opened it up:
So I started out doing some research. I was able to locate the wiring diagram thanks to this forum. I'm using drawing 611-1142(attached). For the cost of replacement parts, I really didn't want to do the research involved with bench testing all of the existing parts. I noticed right away that the start solenoid was cracked and wasn't original. So I bought the following items:
Start Solenoid K1: 307-1617
Crank & Run Ignition Relays K2 & K3: 307-1575
Fuse Holders F1 & F2: 321-0175
Rectifiers CR1 & CR2: 357-0030
Start Stop Switch S1: 308-0383
I didn't buy the Relay Charger K5 (TCA4004) because I want to see if I can make this thing run before I buy an $80 part. I also didn't buy Relay K4 (307-1618) because I couldn't find it.
So today I rewired the control box. I took my time and triple checked every connection. Got rid of the splices the previous owner made, and put everything back to original as best as I could.
The problem I'm running into is that if you look at the picture of my control box when I openned it up, the K4 relay is not original. When I look at the wiring diagram, It looks like this relay is only needed if the unit has the Sisson choke, but mine does not (Onan). My control box part number is 300-1694. My question is, do I need relay K4? If I do, what is it for and is the part number 307-1618? Also, anyone know what size nuts are needed for the K1 terminals?
As I mentioned before, I did quite a bit of research and I found instructions on this forum to simplify the wiring. I don't want to do this because there is a remote control in the boom bucket and I'm afraid that removing certain components will remove my ability to control the generator from the boom. I'd appreciate anyone's help. Thanks
Old 03-18-2017, 10:56:42 PM
LRomero LRomero is offline
Default Re: Onan 4.0 BFA on a Versalift Boom Lift
That's a neat lift!! What is the generator used for if the engine is driving the hydraulic pump? Also, looks like the outrigger stabilizers are missing. If they truly are missing, make sure you replace them before getting in the lift!
Old 03-19-2017, 12:13:20 AM
Ben Cowan Ben Cowan is offline
lift probably has 120 volt power in lift bucket. worked for a sign guy with crane trucks w buckets and generator on them was also a welder. 120 volt outlets were in bucket for drills and other 120 volt power tools. not sure about this unit, couldnt see outlets. Ben
Old 03-19-2017, 12:51:43 AM
BigBlockChev's Avatar
I believe the nuts are a standard fine thread ie 5/16 NF used for any of the commonly available starter solenoid/relays. The charge relay enables 2 stage charging of the battery depending on voltage. I am not an expert on the BFA but have seen them with a PTO similar to that setup. Seems like a practical setup. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
Old 03-19-2017, 10:19:40 AM
Thanks for the replies everyone.
Thanks! It's a pretty cool setup. The engine is used to drive the generator and the hydraulic pump. There is a hydraulic reservoir that feeds the pump. The pump discharges to a header with three valves. Two of the valves control the hydraulic rams, the third valve controls a hydraulic motor that drives a chain connected to a large sprocket, that rotates the boom. There is a 120V outlet in the bucket that is powered by the generator. There is also an outlet on the boom base. The previous owner also attached an electric motor and pump setup (from a dump trailer I believe) to act as an auxiliary hydraulic system. The motor is powered by the generator. I'll take some more pictures to show the details.
You're right the outriggers have been removed and a much wider axle was added. It's so wide I couldn't get it on my car trailer. I was able to get the seller to come down $200 because I mentioned that the outriggers were gone. Here's what it should look like:
My dad is a retired nuclear certified welder, so once I get the boom working, we're going to weld up a new trailer frame with some retractable outriggers. I guess the previous owner who butchered the entire machine didn't want to take the time to put outriggers down. The axle is very wide and it has load range E tires on it, but I still wouldn't trust it, unless you're just going straight up inline with the trailer and not rotating.
Ben, you're right. There is 120V power in the bucket. There are also electronic controls for the hydraulic valves in the bucket as well, to raise and rotate the bucket.
Thanks for the info on the nuts. I think the solenoid should have came with them. Oh well.
I think you're right about the charge relay. From my research I've come to the same conclusion. However, I believe the charge relay is labeled K5 (green box) in the attached diagram. The relay I'm confused about is K4 (red box). I can't figure out if I even need this relay. It doesn't look like it but I could be wrong.
Name:	k4 and k5.jpg
Old 03-21-2017, 03:03:55 PM
So I tried out my rewired control box and it doesn't work. The solenoid is clicking, but the generator isn't spinning. I'm using a genuine Onan solenoid. I disconnected the step charger (K5) and never connected K4. The weird thing is, that when I was testing voltage at various points, something must have grounded and the generator did turn. So, I have a few questions:
1. Do I need to connect relay K4 if I have an Onan choke?
2. Does low oil pressure to S3 remove the ground contact?
3. Should I just ground the wire to S3 to remove the oil pressure switch from the equation?
4. I was getting about 7.6V at the SI terminal when hitting the start switch, should I be getting the full 12V?
5. I had 12V at S1, I've read that there should be 0V at S1 when the switch is in the neutral position.
6. The only thing grounding the box to the generator frame is hex head screw. Should this be sufficient for grounding or do I need to ground some other way?
7. Does anyone have a good copy of 611-1142 that you can actually see all of the relay numbers? My email is in my profile.
Old 03-21-2017, 03:43:21 PM
Kevin K Kevin K is offline
No, the relay is not needed with the Onan choke. It is used with the sission choke.
S3 opens on low oil pressure, and closes on good oil pressure.
Only for a test. You do not want to disable shutdown on low oil pressure.
Yes, you should be getting the full 12 volts, the same voltage as the B+ terminal. Check the voltage at the B+ terminal on the solenoid when cranking, if it is substantially lower than 12 volts, you have a bad battery connection or a discharged battery.
You should have zero volts at S1 (on the start solenoid) with the switch in the neutral position when the engine is stopped. When the generator is running, then you will see the exciter voltage, about 30 volts.
It wouldn't hurt to run a heavy wire, say #12, from the control box ground point to the negative battery lead. A bad ground can cause all kind of trouble.
The copies Onan scanned often leave something to be desired. Try downloading the 900-0186 Wiring Diagram manual from the Twinslan site. A copy of 611-1142 is there.
Old 03-21-2017, 03:50:37 PM
Billy J Shafer's Avatar
This should give you what you need.
Old 03-21-2017, 04:20:35 PM
Look on post #18 here, open up the diagram that has -02 after it, it is a lot clearer.
https://www.smokstak.com/forum/showthread.php?p=1215367
Old 03-21-2017, 05:55:56 PM
One other thing to check. Versalift may have modified the wiring to add more controls. Might be a good idea to ask them for a print. Of the machine.
Best Way to Lift an Onan 4.0 CCK Jim McIntyre Onan Generators 27 05-06-2015 11:32:27 PM
How To Lift an Onan CCK Pherjeby Onan Generators 17 11-23-2012 10:52:43 PM
Boom! David Hoover Steam Stationary Engines, Traction Engines, Steam Boats 1 05-17-2009 06:58:18 PM
Torch + fuel pump=BOOM !! Wayne Z. Antique Engine Archives 7 04-15-2002 08:25:24 AM
