CSG-6491-6005-A 45Kw
this thread has 10 replies and has been viewed 742 times
Old 03-18-2017, 10:19:54 PM
radiotech radiotech is offline
Default CSG-6491-6005-A 45Kw
Hello everyone. I have a 45EM generator with a Ford CSG-6491-6005-A engine.
How do I tell the date of manufacture of the engine from the engine nameplate?
(Generator was made in Jan 1995)
Model Number CSG-6491-6005-A
Serial Number 23228 F-16-RA
S.O./Options 0034F
Model Code NFA-0034-NBB
Also, I need some new spark plug wires, but Onan wants $150 per wire. Does anyone know where to get them for less.
Old 03-18-2017, 10:27:00 PM
Default Re: CSG-6491-6005-A 45Kw
If you want pre-made wires, go to the auto parts store and tell them you want a set for a Pinto of the same vintage. Or buy a set of cut to fit and make your own. (were they still building Pintos in 95?)
Old 03-18-2017, 10:34:49 PM
No they built the Pinto from 1960-74 and google says it is one of the 50 worst cars of all time.
Old 03-18-2017, 10:43:47 PM
It is a 6 cylinder. Get wires for a Ford truck with a 300 (4.9L) engine.
By the way, what kind of "radio"?
Old 03-18-2017, 10:43:57 PM
BRae's Avatar
BRae BRae is offline
I agree with Wayne. a set of plug wires from an early 90's ford truck will work just fine. A good close up picture of the distributor with one spark plug wire un-plugged from the dist cap will let us know if its the newer style or older style ignition.
Old 03-18-2017, 10:58:13 PM
Billy J Shafer's Avatar
That engine is nothing more than a Ford truck or car engine. Tune up items are standard Ford. Onan just added a few items to make it a generator engine.
Max is thinking of the 423 Ford engine.
The Following 2 Users Say Thank You to Billy J Shafer For This Post:
Old 03-19-2017, 12:33:16 AM
Thanks for the replies!! I also think it is like a 1990 F150 with the 4.9L engine. Will have to post pictures like BRae suggests.
Old 03-19-2017, 02:35:50 PM
soundbos soundbos is offline
Pintos were built from 1971 -1980
The 2.3 L 140ci motor was from 1974 till late 90s as 2.3 and 2.5 L
Pintos Mustangs Rangers Areostar Van and Industrial motors Very reliable engine Just replace timing belt
Butch
And yes a 45KW generator would have a 300ci 4.9L 6 not the Pinto motor
The Following User Says Thank You to soundbos For This Post:
Old 09-22-2017, 07:56:53 PM
Does anyone know how much coolant (antifreeze) a 45EM holds with the 300ci Ford Engine?
Old 09-22-2017, 08:10:26 PM
This literature for the 45EM says 20 quarts. https://www.smokstak.com/forum/showp...65&postcount=7
It also states "specifications may change without notice".
The Following 2 Users Say Thank You to Wayne 440 For This Post:
Old 09-22-2017, 10:50:51 PM
Thanks for the reply.
GE 45KW Generator dwight44 Military MEP and Aircraft Gen-Sets 26 04-24-2017 09:38:07 PM
Onan CSG-6491-6005-A 35KW Nymble Onan Generators 4 08-31-2016 07:37:44 PM
Need manual 45kw poinciana Onan Generators 10 11-18-2010 11:16:06 AM
Need vlv cvr gsk for FORD 330DF-6005-A Christopher Madden Vintage Diesel and Oil Engines 1 11-12-2009 05:32:55 PM
Need help with old(er) 45KW Delco gen set Bob Greene Generators & Electric Motors General Discussion 3 03-27-2006 01:23:41 PM
