Onan 4BGEF J30981E, need Service Manual
this thread has 6 replies and has been viewed 292 times
Old 03-18-2017, 10:59:11 PM
Bill Aggenbach Bill Aggenbach is offline
Default Onan 4BGEF J30981E, need Service Manual
Having Trouble Finding a Manual For Spec E, Have found Spec A - C
Serial Number is D880112365
Email is baggenbach@centurytel.net
I am also wondering were to find Description of Option Codes. I have the following options A279, B26, B183, F148, K917, and Z497
Bill
Old 03-19-2017, 08:39:33 AM
MBB MBB is online now
Default Re: Onan 4BGEF J30981E, need Service Manual
Here are the option descriptions.
A279 Heavy Duty Starter
B26 Special Generator end with Separate Battery Charging
B183 15 Amp regulated battery charging
F148 Heavy Duty Mounts
K917 Control with remote instant kill
Z497 RV Application Standard Mounting
The Following 5 Users Say Thank You to MBB For This Post:
Old 03-19-2017, 10:12:56 AM
Pauls12 Pauls12 is offline
If you are looking here http://www.twinslan.net/~n0nas/manuals/onan/ I found 1 manual...965-0232 for spec E
The Following User Says Thank You to Pauls12 For This Post:
Old 03-19-2017, 12:40:04 PM
len k len k is offline
That's the parts manual. For service manual I'ld use
BGE spec f-k---NHE-spec e-k--EMERALD PLUS--SERVICE--(9-94)--- 965-0528
Not sure they wrote a service manual covering spec E
The previous service manual was
BGE-BGEL spec a-c SERVICE--(5-89)--- 965-0530
However those gens used a transformer AC voltage "reg" vs an electronic AC voltage reg.
The Following 2 Users Say Thank You to len k For This Post:
Old 03-19-2017, 12:54:53 PM
Thanks for the tip on which manual to use Len, I will download it and look at it. Thanks MBB for the info on the options. Those seem to be some interesting options.
Old 03-19-2017, 02:01:56 PM
IF it's been sitting for months clean slip rings in genhead to protect the ~ $240 AC voltage reg. VR1
Old 03-19-2017, 07:32:47 PM
Unfortunately its been 9 years. I am aware of the slip ring issue and if I buy it I will do that. Right now it has a dead 11 year old battery that I could not get to take any charge. Owner does not want to invest in a new battery. I told her it is not worth much without seeing it run.
Onan NH-MS / 1918c Owners Manual/service Manual? Help Max Payne Onan Generators 2 01-31-2016 08:41:41 PM
Onan 4BGEF bogs down under load; service manual Tombeaman Onan Generators 5 04-06-2013 06:13:11 PM
Need Manual Onan 6.5NHE 1R/26101A SERVICE MANUAL FunDay Onan Generators 13 06-16-2012 12:21:55 PM
Onan Service Manual jpjohnso Onan Generators 9 02-04-2012 12:10:57 AM
Onan manual for 4bgef jjvw Onan Generators 0 09-01-2010 06:00:51 PM
