Onan OTPCA Transfer Switch
this thread has 4 replies and has been viewed 367 times
Old 03-20-2017, 08:11:15 PM
radiotech radiotech is offline
Default Onan OTPCA Transfer Switch
Hello Everyone. I have an used OTPCA transfer switch that I am installing. This ATS has the LED Bar Meter installed. The current transformers have a long cable that plugs into a circuit board on the side wall, but I am trying to figure out how the CT's are mounted. Do they just have the power cables looped through them or are the some mounting brackets that are missing. Does anyone have experience with installing these CT's?
Old 03-20-2017, 08:58:49 PM
MBB MBB is offline
Default Re: Onan OTPCA Transfer Switch
Do you have the installation manual 962-0612A? If not go to twinslan site and download. Page 3-2
http://www.twinslan.net/~n0nas/manua...0(10-2002).pdf
Picture would help. I may have misunderstood the question. Are the CT's loose?
Old 03-20-2017, 10:12:28 PM
EricWood's Avatar
EricWood EricWood is offline
Yes, the CT's go on the load cables that connect on the side. Just slide them on--the load cables are a single pass straight through. Just make sure that "A" phase CT is installed on "A" phase load cable, etc. Also, make sure the CT polarity (should be a small white or black dot on the side of the CT "donut") is pointing towards the power source. [Polarity dot will face the switch mechanism once mounted on the load wire, and wire installed to switch.]
The Following User Says Thank You to EricWood For This Post:
Old 03-21-2017, 07:52:00 AM
Thanks for the replies. I have the installation manual. I just seems strange to me that the CT's just dangle there with the cables passing through. The older OT switches that I have installed all have a mounting bracket that support the CT's. I guess the cables won't be moving around so it will be ok.
Old 03-21-2017, 10:33:08 AM
Billy J Shafer's Avatar
The mounting system disappeared years ago. Really no need for it. Since the cables never move. Just follow Eric's advice.
Onan Transfer Switch chadred Onan Generators 2 12-15-2016 01:29:41 PM
Onan OTPCA-4965299 transfer switch FDChief Onan Generators 3 09-28-2015 05:34:46 PM
Onan transfer switch. farokh Onan Generators 18 08-10-2015 08:25:36 PM
onan transfer switch kdchester Onan Generators 2 10-08-2013 09:22:50 AM
onan transfer switch kdchester Onan Generators 3 09-23-2013 09:22:40 AM
