Onan Parting Out Thread (Used Onan Parts only!)
this thread has 515 replies and has been viewed 37763 times
Old 11-27-2016, 09:34:17 PM
yellowlister yellowlister is offline
Default Re: Onan Parting Out Thread (Used Onan Parts only!)
Pulled some.more parts out.. standard compression heads for cck..
High points box for a cck..
governor adjustment brackets for jb jc..
djb centrifugal switch.. jb centrifugal switch cover.. I also have the switch for a jb..
jb jc and dje and djb cylinder heads complete with rockers valve covers and push rods and tubes..
Lots of dje jb and jb cooling tins.. sorry no.doors..
Also a 6.0 DJE injection pump.. it's stuck.. even after sitting submerged in cleaning solvent for 2 months..
Jb jc or djb oil dips tickets as well
DJE or djb fuel filter assembly
DJE djb exhaust manifolds and dje louvered exhaust manifold cover for pressure cooled that has the louvers that open when it gets hot
DJE djb fuel pump tested and works good
ID:	268976   Click image for larger version
ID:	268977   Click image for larger version
ID:	268978   Click image for larger version
Old 11-27-2016, 09:59:44 PM
Joe, how much for the JB/JC points cover and the JB/JC Carb. inlet elbow?
Old 11-28-2016, 12:59:16 AM
The elbow may be sold.. I'm not sure if it's the right part he needs.. waiting for a reply from him.. if it's not what he wants then yes there yours
The Following User Says Thank You to yellowlister For This Post:
  #134
Old 11-28-2016, 02:01:43 AM
Jim McIntyre's Avatar
Originally Posted by yellowlister View Post
...jb jc and dje and djb cylinder heads complete with rockers valve covers and push rods and tubes...
I have some interest in a head for a JB - looking for Onan 110-1440 (spec'd for gas and gas/gasoline engines.)
I've been wanting to tinker at milling it down a touch to see if I can get more power on my 6.5:1 CR natural gas-powered sets...
Old 11-28-2016, 03:14:38 AM
I don't recall if any of them are from a tri fueled unit.. will check numbers tomorrow
  #136
Old 11-28-2016, 09:35:58 AM
BHoward BHoward is offline
Hi. Yellowlister I,m looking for a starter solenoid and starter drive for a 6.ODJE. Thanks . Bill H.
Old 11-28-2016, 10:50:27 AM
ArodaPowerCo ArodaPowerCo is offline
Parting out the generator in this thread:
https://www.smokstak.com/forum/showthread.php?t=147120
35EF with 292 Y-block Ford V8. The rotor and stator are gone, but everything else I have. Including all the tin and side doors.
Old 11-28-2016, 01:24:17 PM
All my starters went to Colorado.. there are new ones on ebay.. ill.try to find the link
Pricey.. but http://m.ebay.com/itm/STARTER-DRIVE-...071?nav=SEARCH
  #139
Old 11-28-2016, 04:06:04 PM
turtmaster turtmaster is offline
yellowlister, do you have any spare ignition coil "compression nuts" and the rubber compression "rings"? i "finished" breaking the one that had a crack in it, when i was doing a interference test for JohnnyC
evidently they dio not make my ignition coil type for very long.
Old 11-28-2016, 05:10:27 PM
I don't remember what your working on?
Onan 12.0 DJC parts tim berkemeier Onan Generators 3 09-21-2011 09:11:12 PM
Onan parts Karl Onan Generators 1 04-17-2008 10:22:27 AM
Online Onan Parts Sales-or at least a parts number B.Ikard Onan Generators 3 06-21-2007 07:07:12 AM
Onan cck parts JDavid Onan Generators 1 03-14-2007 10:17:16 AM
Parting out engines thread Handlebar99 Antique Gas Engine Discussion 19 03-27-2006 09:44:37 PM
