4.0cck-3cr/12017R Natural gas derating, gaskets, and circuit boards
this thread has 1 replies and has been viewed 880 times
Old 04-28-2013, 05:04:51 PM
gchank gchank is offline
Default 4.0cck-3cr/12017R Natural gas derating, gaskets, and circuit boards
Just got my new dual fuel carb for the 4.0. I understand the engine is the same as the 5.0 so if I go to natural gas do I still derate?
The manuals I recieved have "old" numbers on the gaskets for the manifold? Anyone off hand know the gasket numbers for the intake and exhaust gaskets?
I am buying a flight panel 300C859 replacement board, what does the one underneath do 300-1227 board? Should I also replace that one?..
Should I also decarbonize the heads while I am in there? Do I replace those or can I reuse them?
Old 04-28-2013, 05:59:11 PM
MBB MBB is offline
Default Re: 4.0cck-3cr/12017R Natural gas derating, gaskets, and circuit boards
You shouldn't have to de-rate. Like you say the motor is the same for the 5.0On the old parts number substitute the letter with a 0 (Zero) . You can check the heads. If your careful you can use the gaskets again. The old gaskets are much better than the new.
Head gasket 110-0892
Intake gasket 154-0013
Exhaust gasket 154-0360
The Following 3 Users Say Thank You to MBB For This Post:
Mama wants bigger than Onan 4.0cck-3cr/12017R gchank Onan Generators 24 04-25-2013 11:59:17 AM
Circuit breakers for Onan 4.0CCK? c east Onan Generators 4 06-17-2011 10:03:48 AM
Onan 4.0CCK Q&D Natural Gas Conversion Pierce Roselle Onan Generators 5 05-26-2011 10:34:44 PM
Natural gas conversion 5.0cck now Works MBB Onan Generators 3 03-18-2011 09:29:37 PM
Onan 4k BGEFA would like to rewire and get rid of circuit boards oldsteveo Onan Generators 9 11-08-2010 09:25:25 AM
