Smokstak Down Under
Wade Drag Saw
this thread has 2 replies and has been viewed 388 times
Old 12-22-2018, 08:09:53 PM
Jonesey Jonesey is offline
Default Wade Drag Saw
Would anyone have a Wade Drag Saw Engine apart, I need the dimensions of the piston and rod as Iím missing both in our engine or does anyone have a spare that they are willing to sell.
Thks Les
Old 12-22-2018, 11:14:23 PM
Alastair Geddes. Alastair Geddes. is offline
Default Re: Wade Drag Saw
i am sure you can measure the crank a tdc to the top of the cylinder, measure the head volume and work out a compression ratio that will work. Work backwards from compression ratio to design a piston then make a rod suitable for the piston pin height so it doesn't hit the rings, just below the bottom ring.
I have a uncle who has a drag saw complete but not sure on brand and likely won't be pulling it apart any time soon so its of no help to you.
The Following User Says Thank You to Alastair Geddes. For This Post:
Old 12-23-2018, 08:29:39 AM
Hi Alastair,
Unfortunately itís a 2 stroke engine so things like the piston design with the flag and compression ratio are an unknown, so I require a sample or dimensions to get a copy made.
Thks Les
Wade Drag Saw jtrojek Drag Saw Collectors 4 08-19-2016 10:53:55 PM
wade drag saw Jeff P Smith Drag Saw Collectors 3 02-18-2016 08:13:20 AM
Wade Drag Saw Rich Fowler Antique Gas Engine Discussion 3 02-08-2012 01:00:47 PM
Wade Drag Saw Walt Roys Drag Saw Collectors 7 10-24-2010 10:08:57 AM
Wade Drag Saw Jeff Wewers Antique Gas Engine Discussion 1 01-14-2007 06:29:12 PM
