Smokstak Down Under
About Time for an Engine Video
this thread has 166 replies and has been viewed 19617 times
Old 08-14-2018, 05:29:49 AM
Nathan Woodruff Nathan Woodruff is online now
Default Re: About Time for an Engine Video
Giving my Cameron Sutherland mixer a test run with my clapped out old Mcdonald diesel. Trying to work out what the ideal drum speed is.
https://youtu.be/IyrEbUT2UsE
The Following 4 Users Say Thank You to Nathan Woodruff For This Post:
Old 08-14-2018, 04:05:59 PM
Scotty 2 Scotty 2 is offline
Still a bit fast I reckon Nathan.
About the only way to really see is chuck in some sand and gravel and mix a batch. Slower is better then quicker.
Are there spiraling flutes/fins in the bowl or are they bits of flat welded as the mixers? My guess would be flutes so you can get the mud out. How do you get the mud out?
Cheers Scott
Old 08-14-2018, 10:13:26 PM
Yes I was thinking might be slightly fast. Might have to put a jack shaft in to help gear it down some more. There are fins and cups, the fins help guide into the cups and the cups lift it up to the top and it falls back to the bottom. None of the fins or cups are tight up against the barrel there is a slight gap to allow for cleaning. There is a bung in the barrel which you can take out and that will drain what ever is left over and allow for cleaning.
Once I put it to work I will do a video to demonstrate it all better.
The Following User Says Thank You to Nathan Woodruff For This Post:
  #164
Old 09-29-2018, 10:56:41 PM
sunshineman sunshineman is offline
Hi all,
Heres my Petter S at the recent Clarendon Classic rally 2018. Sorry about the background noise.
https://youtu.be/8suib7JkFY8
Regards,
Sunshineman
The Following 3 Users Say Thank You to sunshineman For This Post:
  #165
Old 12-25-2018, 01:12:10 AM
Not exactly an engine video but might still be of interest.
https://www.youtube.com/watch?v=TrLt5vED7sw
It is a video of recently acquired Kelly and Lewis Centrifugal pump size 1 type H
I would be interested to know what the max rated speed is for it.
Cheers, Nathan
The Following 2 Users Say Thank You to Nathan Woodruff For This Post:
  #166
Old 12-26-2018, 03:00:16 AM
Hello Nathan
Thanks yet again for another video. I've heard about a Kelly and Lewis pump sitting in a shed in town. I have yet to investigate. From what's been told to me, it has Kelly and Lewis cast on the impeller cover.
Cheers Scott
Old 01-03-2019, 01:28:42 AM
Something a bit different for this thread some video from a New Years Eve steam up at Lake Goldsmith.
https://www.youtube.com/watch?v=iSnjA9k7CIY
The Following 3 Users Say Thank You to Nathan Woodruff For This Post:
Old Time Video Full of Machinery - Be warned, no gas engines! MFaris Antique Gas Engine Discussion 1 01-08-2018 08:34:59 AM
Sawing down a big tree one piece at a time. Interesting video OTTO-Sawyer YouTube Old Iron Videos 10 03-05-2013 03:36:24 PM
Blast back into time 1904 in the Westinhouse Engine Factory - Video Wayne Grenning Antique Gas Engine Discussion 13 11-13-2012 07:28:51 AM
Awesome video - Triumph Spitfire Engine Rebuild Time-Lapse Video KD5BYB Antique Gas Engine Discussion 6 07-01-2012 12:07:33 PM
