Smokstak Down Under
Pump Designer on Drugs
this thread has 32 replies and has been viewed 2018 times
Old 10-07-2018, 05:12:46 PM
G.M.Johnson G.M.Johnson is offline
Default Re: Pump designer on drugs
I'm going with the principal of centrifugal force. Water enters through the middle and by way of centrifugal force, forces the water out of the tubes, to the discharge port. It probably actually made some good pressure believe it or not. Take a piece of copper tube, fill it up with water and then whip it and see how fast the water comes out!
Old 10-07-2018, 05:15:09 PM
Scotty 2 Scotty 2 is offline
Originally Posted by Darryl View Post
I think hydraulic motors are fed from the outer side of the " impeller" to exert the main energy onto the biggest diameter and then be expelled through the center. It might work with pressure from the center but i dont think so.
If it did then it wouldn't be with much force with the head height pressure from an overhead tank. 20' height height is a bit less then 30 PSI though.
Cheers Scott
Old 10-07-2018, 05:45:47 PM
Darryl Darryl is offline
Centrifugal force is what its all about, there's no doubt but the main thing with any pressure pump is sealing the impeller inlet to the suction pipe as it will just recycle more and more as the pressure goes up
Old 10-07-2018, 06:24:13 PM
typak typak is offline
Just a type of 'closed impeller' pump? and not a 'open impeller pump' .......
Old 10-07-2018, 10:28:02 PM
DaveMisch DaveMisch is offline
I agree with Johnson in 21. The impellers don't make any near contact with the sides of the pump. They are throwing the water out by centrifical force putting pressure on the outlet side and a suction on the intake.
Old 10-08-2018, 12:04:40 AM
It is a centrifugal pump, there is no question about it. It's just a stupid but interesting idea.
Old 12-04-2018, 04:09:32 AM
So have you tried it out yet Darryl? I'm pretty curious on just how well it pumps.
Cheers Scott
Old 12-04-2018, 01:32:40 PM
Default Re: Pump Designer on Drugs
Hi Scotty, no,not yet.
In the middle of India at the moment. Seen a thousand real Listers and twice as many Indian copies on the side of the road usually powering compressors . Went past a big farmland in a car and spotted a big Ruston Hornsby pumping water ,just out in the open. Also saw a McDonald road roller still working. Before you ask, I don't have photos because we were in a hurry driving somewhere yesterday and did 800 kms. Will get some though.
The Following User Says Thank You to Darryl For This Post:
  #29
Old 12-04-2018, 03:07:42 PM
For God's sake......don't hit a cow.
The Following User Says Thank You to Scotty 2 For This Post:
  #30
Old 12-04-2018, 09:15:54 PM
Ifix71 Ifix71 is offline
The designer didn't know about cavitation, drag and hasn't looked at anyone else's impeller design in my opinion.
I just keep thinking , WHY ?
The liquid being pumped is drawn through the tubes by centrifugal force from the central opening The suction can be quite substantial at higher speeds possibly more efficient and pump at a higher pressure than a traditional centrifugal pump. somebody with more time and a good Calculator can do the math
John
Hardie Model 99 Senior Duplex Pump (Sprayer Pump) parts? MotoXkid Farm + Industrial Antiques and Collectibles 25 02-08-2017 12:41:01 PM
Kudo's to the Armature Housing designer Nick Lingg Antique Gas Engine Discussion 0 04-24-2014 03:30:47 PM
Deane steam pump co. water pump info needed Nick McCue Antique Gas Engine Discussion 2 08-07-2011 06:59:51 PM
Ebay find,Monitor Pump Jack engine complete with pump and arms Benny Mckheean eBayŠ Auction Discussion 1 09-02-2005 06:27:14 PM
