Smokstak Down Under
Piston pump for screen cooling
this thread has 5 replies and has been viewed 584 times
Old 12-03-2018, 03:52:44 AM
Engineman87 Engineman87 is offline
Default Piston pump for screen cooling
Hi all,
Wishing to set up a screen cooler on one of my
Engines and was wondering if a Ajax style piston pump would be fit for use. Given it’s sucking from the cold side I figure the temp wouldn’t get above 80 degrees at a guesstimate. The engine is a lister cs driving an ac alternator.
Any input would be helpful.
Regards.
Old 12-03-2018, 04:11:29 AM
Scotty 2 Scotty 2 is offline
Default Re: Piston pump for screen cooling
Hello Engineman
Are you talking about something like an Ajax A2? If so then maybe a bit overkill?
Cheers Scott
Old 12-04-2018, 12:32:30 AM
Yes Scotty2 I am referring to an inch and a half model.
It may be overkill but would the temperature of the water be an issue? I have tried to source brass gear pumps however have not been successful as yet therefore I looked for an alternative.
Old 12-04-2018, 02:43:37 AM
Hello Engineman
There's usually one or so on ebay I think.
https://www.ebay.com.au/itm/VINTAGE-...wAAOSw22FcBLav
This one is too dear I reckon.
https://www.ebay.com.au/itm/Old-Vint...4AAOSwMjtbzHTj
Even a little 1/2 or 3/4" centrifugal pump would be better. You can have a tap on it to restrict water flow if needed.
Cheers Scott
Old 12-04-2018, 03:26:37 AM
Thanks Scotty, my thoughts exactly on the top expensive part re the second pump, last one I bid on went way past that amount. I have centrifugal pumps but none under 1.25 inch. I will investigate the first pump and if not successful will keep looking for a gear pump that is priced within reason.
Cheers =]
Old 12-08-2018, 07:30:33 AM
Phil Dowe Phil Dowe is offline
I have been using CS Listers for work,and they have to work long hours. I just use a poly 44 gal tank, thermo syphon, BUT I put a small thermostat, where the outlet is from the head, and also a small bypass, that has a tiny gate valve to govern the rate, from a tee piece on the outlet side of the pump,into the bottom of the poly tank. There is also an outlet from the top of the poly tank,to take the excess away. I just let it run back into where the water is being pumped from. The amount of flow is really just an old mans piddle!! The engine stays at a good working temp, and the tank never gets hot! Regards Phil.
IHC screen cooling tank question CLips221 Antique Gas Engine Discussion 2 10-31-2014 06:20:51 PM
IHC Screen Cooling RADIATOR dmcdjr Antique Gas Engine Discussion 3 10-19-2013 08:26:51 AM
IHC screen cooling tank Alex F Antique Gas Engine Discussion 2 06-08-2007 12:59:52 PM
IHC screen cooling tanks----dimensions qlder Antique Gas Engine Discussion 0 06-25-2006 06:07:01 AM
Screen Cooling Tanks Dan Burkart Antique Engine Archives 0 08-04-2003 09:06:41 PM
