Smokstak Down Under
Buried Treasure in Creek Bed
this thread has 40 replies and has been viewed 12581 times
Old 12-09-2012, 04:22:27 AM
jelbart
Default Re: Buried Treasure in Creek Bed
good stuff Joe when we started digging it out i did not think that the bore would ok but the engine angels must have been with us when we dug it out ...
Old 12-09-2012, 07:06:05 AM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
Thanks for the update, also a nice looking Emerson in the background. F.J. W.
  #33
Old 12-25-2012, 07:33:50 PM
Joe McClelland Joe McClelland is online now
i managed to find and buy original transports for this engine the same size as the chassis that was under it all bolt holes matched,and is now back on it's wheels
a long time from when it was first built maybe 110 years ago
joe
ID:	153136   Click image for larger version
ID:	153137   Click image for larger version
ID:	153138   Click image for larger version
The Following 12 Users Say Thank You to Joe McClelland For This Post:
  #34
Old 04-09-2018, 12:43:51 AM
I finally got around to doing some work on the Coulson, i wanted to make it run with the original side shaft but it was to far gone, so i had new gears made and made new cams for it .
Joe
ID:	307754   Click image for larger version
The Following 5 Users Say Thank You to Joe McClelland For This Post:
  #35
Old 04-09-2018, 05:12:13 AM
Managed to get the shaft mounted on the engine to day.
Old 04-09-2018, 05:41:31 AM
What's wrong with that shaft? It looks WAY too shiney!
Doc
The more I learn about science the more I learn the universe really is out to get me!
  #37
Old 04-10-2018, 02:03:20 AM
cobbadog cobbadog is offline
You would only need to leave that shaft out in the open here for a couple days and it would look as if it was original. The salt air here will rust out plastic buckets.
The Following 3 Users Say Thank You to cobbadog For This Post:
  #38
Old 04-10-2018, 05:44:42 AM
Images: 4
Great stuff Joe. I look forward to seeing it running.
Patrick
The Following User Says Thank You to Patrick M Livingstone For This Post:
  #39
Old 04-10-2018, 05:18:53 PM
Thanks Patrick but it still has along way to go , i need to make some pattens and get some castings done .
Yes it needs to rust a little but that will happen over time as it is not sheded , we are luck that it is a dry climate here and rust is not to bad, cast iron is not affected mostly it is usually the steel that rusts .
But being upside in a creek bed for 90 years or so didn't help this engine either.
Joe
The Following 3 Users Say Thank You to Joe McClelland For This Post:
  #40
Old 04-26-2018, 06:15:10 PM
I got the oiler finished and mounted , there was some of the original studs left so i welded nut to them to get them out, it took a bit of time to get the oiler to work right .
A lot this engine looks like it was copied from the early Crossley engines ,the flywheels are the same and the governor and oiler are similar , Wayne Grenning governor drawing are very helpful , thanks Wayne .
ID:	309155   Click image for larger version
ID:	309156   Click image for larger version
Buried Engines Casemaker Steam Stationary Engines, Traction Engines, Steam Boats 127 04-11-2016 05:51:42 PM
Buried Engine Identification? Blair Goss Antique Gas Engine Discussion 7 11-24-2008 08:36:10 PM
We're BURIED! Chris Kirk Antique Engine Archives 19 02-18-2003 03:28:25 PM
