15 27 case tractor
this thread has 7 replies and has been viewed 2694 times
Old 02-05-2014, 07:00:59 AM
blackstone20hp blackstone20hp is offline
Default 15 27 case tractor
will parts from a 18 32 cross case fit on a 15 27 I am after a complete clutch set up thanks
Old 02-05-2014, 08:08:44 AM
Rick McKay Rick McKay is offline
Default Re: 15 27 case
I have a 15-27 parts book. If someone could look in the 18-32 parts book at some part numbers for the clutch, I could check if it matches up to the last version of the 15-27 clutch. There were 3 different clutches used in the 15-27. If memory serves, there was a Case clutch, Borg & Beck, and Twin Disc.
Show us a picture of that Case,
Rick
The Following User Says Thank You to Rick McKay For This Post:
Old 02-05-2014, 12:33:49 PM
Phil Johnson's Avatar
Default Re: 15 27 case tractor
I have both parts books and it appears that the Case clutch and the Borg & Beck clutch were the same for the two tractors. The Twin Disc was only used on the 18-32.
It'll be done in good time---impossible might take a little longer!
The Following User Says Thank You to Phil Johnson For This Post:
Old 02-05-2014, 12:35:01 PM
Ken Majeski's Avatar
Ken Majeski Ken Majeski is offline
I had both a 18-32 and a early 15-27. The 1919 15-27 had a shoe type clutch similar to the steam engines so those parts including the pulley would be different. If I remember right the 1928 18-32 had a twin disc.
I don't have a clue if you could change the whole assembly pulley and all I know there are a Lot of differences between the early 15-27 and 18-32
Ken Majeski, Ellsworth Wis.
The Following 2 Users Say Thank You to Ken Majeski For This Post:
Old 02-06-2014, 04:12:55 AM
its number 49839 trying to load a few pics thanks for your replys
The Following 2 Users Say Thank You to blackstone20hp For This Post:
Old 02-06-2014, 04:20:23 AM
The Following 10 Users Say Thank You to blackstone20hp For This Post:
Old 02-08-2014, 11:52:30 AM
Inverted's Avatar
Inverted Inverted is offline
Just want to bump this back to the top to help Josh out on his quesion? I some years ago worked on both and knew that there was a difference but can't remember exactly what the difference was. So Josh needs help from the Case men that may know and help him out. - Thanks - Ted
Old enough to know I won't get all the projects done that I have started BUT young enough to still think I can
Old 02-08-2014, 02:26:20 PM
Kevin Watson Kevin Watson is offline
Originally Posted by blackstone20hp View Post
Is this Case a very late 15/27 as it has a lot of the 18/32 features on it.
20-40 Case Tractor Gene Williams Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 17 09-10-2010 02:27:24 PM
Odd Case 500 Tractor Meco3hp Antique Farm Tractors 11 02-05-2010 09:28:24 PM
Case DI tractor Andy Williams Antique Farm Tractors 2 05-20-2008 03:06:23 AM
Case tractor. 20 Reeves Highwheeler Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 06-22-2006 06:25:32 PM
20-40 J. I. Case tractor Craig A Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 01-27-2005 10:12:36 PM
