Smokstak Down Under
Bridgetown Russels field day
this thread has 4 replies and has been viewed 335 times
Old 03-28-2019, 10:26:48 PM
RustyNumbat RustyNumbat is offline
Default Bridgetown Russels field day
Just a very few photos I took from the day, might have a video together eventually. Big thanks to Chester for giving me loads of advice and trying to help me with the Lister that DEFEATED GREASY JOHN
Link to the album
The Land Rover looked incredible!
The Following 2 Users Say Thank You to RustyNumbat For This Post:
Old 03-29-2019, 12:06:49 AM
karragullengine karragullengine is offline
Default Re: Bridgetown Russels field day
Looks like a really good day out. One day I'm hoping to get to some of these events. So did you get the lister going and if so what was wrong?
Old 03-29-2019, 01:04:17 AM
GreasyJohn GreasyJohn is offline
ahem please dont forget to add the bit where i had it running albeit poorly due to what i have diagnosed as a weak spark. i think we should all encourage Numbat to find a new HT lead and work on his soldering ability
Old 03-29-2019, 02:48:07 AM
"There's no spark!" said the guy who refused to stick finger between lead and plug to demonstrate his initial diagnosis. Not to mention it ran fine under identical electronic configuration only a month prior
It was good to see the tractor pull sled being used, I wonder if it's the one from Dardanup. Some bloke even put their hotted up land cruiser onto it! Though I have to say it's a bit silly when large HP machines go on it, they all simply pull it to the end of the sled run with no problem so there's seemingly no challenge!
Old 03-29-2019, 11:59:05 PM
Here's the video, though it's mostly just a troublesome Lister and not very much of the show. Turns out when you actually bring gear to the show you spend time doing that instead of taking a decent amount of video!
https://www.youtube.com/watch?v=_0UkIq1szTU
Field Brundage "Field Jr" /Ideal Type C /Novo 3 Hp Vertical Len Spoelman Antique Gas Engine Discussion 9 12-19-2018 08:49:24 PM
Field-Brundage (Rayner Field) 5-1/2hp. Denis Rouleau Antique Gas Engine Discussion 3 09-05-2018 01:53:04 PM
Bridgetown W.A. Agg Show ronald shane newport Smokstak Down Under 1 10-23-2016 05:27:33 PM
Field @Brundage Kurt Antique Engine Archives 2 08-13-2004 09:52:38 PM
Exciting the field/ Flash the field?? Gary Bright Generators & Electric Motors General Discussion 1 03-18-2004 10:46:06 PM
