Smokstak Down Under
Blackstone vs Clutterbuck/Perry?
this thread has 3 replies and has been viewed 518 times
Old 04-10-2019, 05:19:03 AM
typak typak is offline
Default Blackstone vs Clutterbuck/Perry?
Little mention that I have seen here in the past, that I can recollect? are the Clutterbuck oil engines, mostly thought of as a copy of the Blackstone, there seems a number of differences in the two makes of hot bulb engines when compared, a gutter around the base of the bed the most obvious and in the case of the 10hp Clutterbuck and other sizes? oil boxes on the mains and a oil pick up ring and sight glass oiler for the rod bearing, any other thoughts of the differences between the engines and the history of the 'Clutterbuck' oil engine? all that said a Clutterbuck seems a unusual sight on the rally field nowadays as compared with the number of Blackstone's being well represented at many events?
ID:	332420   Click image for larger version
Name:	clutterbuck perry.jpg
ID:	332421   Click image for larger version
ID:	332422   Click image for larger version
The Following 4 Users Say Thank You to typak For This Post:
Old 04-14-2019, 02:02:12 AM
isandian isandian is offline
Default Re: Blackstone vs Clutterbuck/Perry?
The last photo was of the Clutterbuck in the sale on 9 March at Nericon near Griffith. Do you know what became of it? I visited the property in early February to check out another engine of interest.
Old 04-14-2019, 06:48:30 AM
Hello Ian, I attended the Nericon auction to see if I could acquire the other engines of interest that were not in the sale, no luck in that regard but at the auction purchased the 10hp Clutterbuck, the 7hp Waterloo boy and a Mitchell engine transport, Clutterbuck had the cooling tower stack missing, chance had it the next week at the Bookham auction I acquired the correct stack for the Clutterbuck, as not a great deal appears wrong with the engine I should have it running soon enough and hopefully show it at the Clarendon rally in September.
ID:	332679   Click image for larger version
The Following User Says Thank You to typak For This Post:
Old 04-14-2019, 07:25:04 AM
How good was that, locating the correct cooling tower! I will look forward to seeing the Clutterbuck at Clarendon. Were the results of the Nericon auction published? I have not seen any prices.
The Following User Says Thank You to isandian For This Post:
Clutterbuck 6 1/2 hp help freshieslures Smokstak Down Under 10 01-31-2016 03:19:45 AM
Clutterbuck Oil Engine. Bug1929 Smokstak Down Under 1 06-27-2014 06:01:40 AM
Perry Diesel Mat Phelps Vintage Diesel and Oil Engines 3 05-29-2014 05:23:04 PM
Perry 'Pip' Stairs tirediron Old Engine Memorials 0 08-20-2013 01:21:22 PM
Perry Oil Engine Nick Smokstak Down Under 8 09-07-2010 05:38:26 AM
