Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Drag Saw Collectors
Drag Saw Collectors Water cooled drag saws; Hercules, Ottawa, Wade, Vaughan, Witte, Timberwolf and Multnomah
Drag Saw Collectors
2 1/2 Ottawa Log Saw
this thread has 3 replies and has been viewed 763 times
Old 05-09-2018, 01:34:01 PM
nss9400 nss9400 is offline
Default 2 1/2 Ottawa Log Saw
Hi,
I bought an Ottawa log saw I think its a 2 1/2 hp and need some information on it.
I want to build a correct log cart for it can someone give me the dimensions of the long wood beams including dimensions for the round handles and the cut out/notch at the other ends for the channel that holds the wheels as a starting point. also I need the dimensions for the clutch gear that attaches to the engine that drives the saw or if anyone has one for sale that I can buy or can make one that would be great.
Thanks,
Nader
ID:	310102   Click image for larger version
ID:	310103   Click image for larger version
ID:	310104   Click image for larger version
The Following User Says Thank You to nss9400 For This Post:
Old 05-09-2018, 02:29:54 PM
MarkBillesbach's Avatar
MarkBillesbach MarkBillesbach is offline
Default Re: 2 1/2 Ottawa Log Saw
what's the bore and stroke on your Ottawa?
Old 05-09-2018, 02:42:20 PM
I am still new to hit or miss engines I think the bore is 4 1/4" (diameter of the hole where the piston is located) not sure what the stoke is or how to figure it out.
Thanks,
Nader
Old 09-25-2018, 11:55:47 AM
Andy Williams Andy Williams is offline
i think it is about 2-1/2 hp. i also think it was the first ottawa saw model made and i think the LS is just for log saw. the ones sold as stationary engines had the hp. stamped on them. I have one like yours with the 2 flywheels I also have a model ES which i think is rated at 4 hp. it has a slightly larger bore and a larger water hopper. It is about the same size as the LS. The later T series throttle governed were 4 and 5 hp and made up until around 1940. Then were replaced by wisconsin air cooled engines until about the early 50s. the LS and ES were made in the 1914-1920 period. I can't help with the saw parts as all were gone except for the 2 wheels when i got it.
Ottawa iolaguy Antique Gas Engine Discussion 4 10-27-2012 10:12:29 PM
Ottawa Log SAW? Doug Oldenburg Antique Gas Engine Discussion 14 09-25-2011 05:04:01 PM
Ottawa log saw DennisFust Antique Gas Engine Discussion 4 10-18-2009 07:16:48 PM
OTTAWA, engine and tractor show in ottawa kansas veedol_al1 Antique Engine Archives 0 09-19-2004 08:16:45 PM
Ottawa rust Antique Engine Archives 1 05-16-2004 09:53:47 AM
