Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Drag Saw Collectors
Drag Saw Collectors Water cooled drag saws; Hercules, Ottawa, Wade, Vaughan, Witte, Timberwolf and Multnomah
Drag Saw Collectors
Drag Saws, must see!
this thread has 21 replies and has been viewed 11431 times
Old 07-14-2015, 10:53:34 AM
Jeff and Maria Smith's Avatar
Jeff and Maria Smith Jeff and Maria Smith is offline
Default Re: Drag Saws, must see!
Chris,
Do you still have drag saw parts to sell?
Old 07-14-2015, 12:28:03 PM
What do you need??
Old 07-14-2015, 01:40:00 PM
I think I have a Timber Wolf or Ward Sawyer (they are the same, I believe).
I need a mixer, which I believe aren't that difficult to find (Lunkenheimer, or that style). The harder parts to find that I need, are the Wico EK mag bracket and trip mechanism, and a cooling tank.
Just checking to see if parts are out there. The piston is stuck and I will have to see if that is going to free up before I go any farther.
Thanks.
Old 07-14-2015, 10:07:50 PM
Chris J Chris J is offline
Images: 833
Yes, I have some parts, I replied to your pm
Thanks, Chris
The Following User Says Thank You to Chris J For This Post:
Old 01-02-2016, 12:44:03 PM
roy davies roy davies is offline
Default Re: Drag Saws, must see!!
my name is Roy Davies and I have a two coloured advertising brochure of several pages and a parts list.I will try to find it and take pictures of them to show you
The Following User Says Thank You to roy davies For This Post:
Old 12-05-2016, 01:18:55 AM
Axtion Jim S Axtion Jim S is offline
Smile Re: Drag Saws, must see!
Chris I need a little help here, I recently found a 4 hp. S&R , not in bad shape. The only issue it has is that the timer is mangled. The brass contact strip is there but the binding ends are bent, it will take some patients to straighten them. The other thing that is cobbelled is the contact and the prowl that is attached to the crank shaft. I have looked at all your photos, (great shots) but nothing is clear enough to make out what I`m missing. If you would be so kind please take a photo of the timer side of the saw motor and I will make the missing parts. Thanks Jim
Old 12-18-2016, 03:34:56 PM
pisfire pisfire is offline
Hi Chris...Havnt spoke to you since you left for school. I have a wade that is taking up space here in Priest River. The engine has lots of compression, spring clutch, 2 saws log dogs. Both tanks need to be fixed and wood. Any ideas? It needs a home....Tnx Brent
Old 12-27-2016, 08:01:05 PM
rholc rholc is offline
Do you have any Appleton parts?
Old 01-06-2017, 02:51:31 PM
Mutt46 Mutt46 is offline
Question Re: Wade saw parts?
Chris
I see you have a bunch of parts and I need the adjusting pillow block for my Wade The top cap was lost, then "blacksmithed" replacement made to work.
Would you have a complete pillow block for sale?
The casting # has "08" on one and "8" on the other.
I can try to send a pic or the video of mine running if that would help.
Old 01-30-2017, 04:50:54 PM
BobRR BobRR is offline
I have a couple of misc. small parts for sale. I believe 2 of the pillow blocks and the steel nose skids are Vaughn. 1 pillow block is wade?? Not sure about the tanks and straps. Make offer. Bob
ID:	273540   Click image for larger version
ID:	273541   Click image for larger version
ID:	273542   Click image for larger version
drag saws Chris J Drag Saw Collectors 27 06-02-2016 06:35:40 PM
Steam Powered Drag Saws Chris J Steam Stationary Engines, Traction Engines, Steam Boats 12 03-12-2014 10:30:42 AM
3 Old saws Danno Chain Saw Collectors 1 07-20-2010 10:34:32 AM
My first old saws Mike in CA Chain Saw Collectors 16 02-24-2010 02:13:24 PM
Ice saws Clark Bigger Antique Gas Engine Discussion 6 02-13-2008 11:08:04 PM
