Smokstak Down Under
Lister help
this thread has 24 replies and has been viewed 996 times
Old 02-03-2019, 10:51:30 PM
RustyNumbat RustyNumbat is offline
Default Re: Lister help
Here it is, thanks for the advice so far everyone
Got a fuel cap for the thing today, bloody ripoof merchants cost me 1/5 what I payed for the engine
The Following User Says Thank You to RustyNumbat For This Post:
Old 02-04-2019, 01:01:59 AM
E27N's Avatar
E27N E27N is offline
LT1 built 1980 ( I think ) LT1’s started in ‘74 and you add the ‘30’ to 1950 to get the year.
I love the smell of 515 in the morning...
The Following User Says Thank You to E27N For This Post:
  #23
Old 02-11-2019, 06:58:08 AM
Fired it up today after cleaning out the fuel tank and bowl. Ran beautifully for the few seconds I let it, got it powering up a lamp as well. Found a pdf online of the shop manual so that's good.
Couldn't figure out what the bung next to the top of the engine block was for, is there meant to be a water jacket or something?
Might have to go give the block an extra $50, I would have paid that if he had known it was in working order.
Old 02-11-2019, 08:45:56 PM
E27N's Avatar
If you mean this one, thatís for adding a small amount of oil to assist cold starting ( helps seal the rings bumps up compression a bit)
  #25
Old 02-11-2019, 09:19:41 PM
Yeah that was my guess Have to go find a matching new fuel filter and then I'd say it's ready to try some hard work with to test the genny out!
Lister 3 hp + lister dynamo 19fingers55 Smokstak Down Under 17 01-01-2015 03:18:52 AM
Lister cs 12/2 robert hamilton Vintage Diesel and Oil Engines 2 12-07-2013 03:00:02 PM
Lister 4kw onan adapted to Lister Iwasthere61 Onan Generators 3 01-31-2013 11:36:54 PM
Lister 12/2 30kw koler generator head COOLING The Lister????? mytickets Vintage Diesel and Oil Engines 2 04-12-2010 04:34:18 PM
Need Lister ST Hat glfarnes Vintage Diesel and Oil Engines 0 09-25-2007 04:53:53 AM
