Smokstak Down Under
John Danks and Son Ltd Pump Flywheel
this thread has 114 replies and has been viewed 7200 times
Old 05-17-2018, 01:01:50 AM
Paul Richardson Paul Richardson is offline
Default Re: John Danks and Son Ltd Pump Flywheel
The flywheel in the old photo above could easily approach 4' in diameter.I make that estimate comparing it to the closest mans height,assuming he might be average height,5'10" or so?(I wonder what he is holding in his hand and resting on top of the rim?)
That would make that wheel similar or a few inches taller than my own?Perspective seems difficult to gauge with such a tall wheel on it's own,and the physical size in my photography is poorly represented I feel?
I have a Bryan pump jack wheel in the background of one photo here which incidently has a similar lazy 's' in the spokes to the old pic above.The Bryan wheel is only 30".No way am I suggesting the wheel in the old pic might be a Bryan.After seeing Nathans example there's every chance it might be a Danks creation?
I sat a firebrick in front of my Danks rim to give some comparison to the rim profile.The other pic is reaching out at chest height to hold the Danks flywheel by the rim.The wheel is quite a serious chunk of cast iron when seen close up.
ID:	310624   Click image for larger version
Old 05-24-2018, 06:19:31 AM
Darryl Darryl is offline
Paul, sorry but it was a case of only having 17.5 seconds
The Following 3 Users Say Thank You to Darryl For This Post:
  #33
Old 05-24-2018, 06:21:46 AM
Also retarded ipad only does one photo
The Following 2 Users Say Thank You to Darryl For This Post:
  #34
Old 05-24-2018, 06:25:26 AM
Pretty big setup to pump water by hand
  #35
Old 05-24-2018, 06:28:25 AM
Now just trying to think of something to say
The Following User Says Thank You to Darryl For This Post:
  #36
Old 05-24-2018, 06:30:25 AM
Must be 4" bore
  #37
Old 05-24-2018, 09:27:14 AM
That was worth waiting for Darryl,thanks very much!
Were any of those 17.5 sec's dedicated to stretching a tape measure by any chance?,...I don't want to have to send you back there
I have no idea how something like that was operated,but I have a sneaking suspicion that the handle would have been long enough to accommodate a second pair of hands?Possibly following the principle of a saw pit,intended for two workers,both facing the job?It's a wild guess but as you point out it's a fairly large pump and might be hard work for just one operator?
Apart from the size question the handle on mine is around the same distance(in perspective) from the crankshaft.
Tell me you measeured the wheel please Darryl
edit:...did I just spot a repair on the flywheel?,i'm wondering what the tab and two screws are about on the outer rim?
Old 05-24-2018, 05:23:12 PM
Probably going past again on Saturday mate. Ill measure it then.
Cheers.
Old 05-24-2018, 09:10:30 PM
It's hard to find good help Darryl!,.. thanks for the photos.
I would be interested to know the hole to hole centre measurement from the crankshaft to the crank handle,as well as the overall diameter of the wheel,if you could do that for me please mate?
While you are at it could you note the deck height of the table from the ground, and centre height from ground to the crankshaft?
pleeezzz?
Old 05-24-2018, 11:06:44 PM
No worries.
John Deere Model D Flywheel gscott Antique Farm Tractors 13 12-24-2017 01:26:57 AM
John Deere Flywheel Ihorse Antique Farm Tractors 5 06-06-2016 01:38:45 PM
John Deere E 1.5 Flywheel Timing ajs2001tx Antique Gas Engine Discussion 1 01-28-2009 01:35:33 AM
John Deere Flywheel’s bodeanoo Antique Gas Engine Discussion 1 03-01-2008 11:25:45 AM
John Deere E flywheel Andrew Delikat Antique Engine Archives 4 02-01-2002 08:35:35 AM
