Smokstak Down Under
Single cylinder 2 stroke marine engine possible ID
this thread has 29 replies and has been viewed 1432 times
Old 01-17-2019, 07:55:23 AM
klanger57 klanger57 is offline
Default Re: Single cylinder 2 stroke marine engine possible ID
Other side
The Following 2 Users Say Thank You to klanger57 For This Post:
Old 01-18-2019, 05:32:18 PM
Scotty 2 Scotty 2 is offline
Hello Kev
I don't think it's a Record but, then again, I could be well wrong. The reason I say I don't think it's a record is I cannot remember the makers tag on the front. I cannot remember any makers plate at all. I'm also pretty sure the magneto mount was cast. But Record cannot be ruled out. We'll find out what it is hopefully tomorrow.
I do this sort of thing quite consistently. Find something a little unusual in the wild and I have to go back to pick it up because the trailer or old Pajero is chockered. In the meantime I forget exact details of what I've found. Kid in a lolly shop
Cheers Scott
Old 01-18-2019, 11:30:08 PM
cobbadog cobbadog is offline
Take the empty trailer and a camera this time silly!
Old 01-19-2019, 08:35:53 AM
rodneyt rodneyt is offline
Cass just put another possibility on one of her fb pages:
"Hall" cheers Rod.
The Following User Says Thank You to rodneyt For This Post:
Old 01-20-2019, 02:09:24 AM
Originally Posted by Scotty 2 View Post
I came across a little marine engine the other day on my way back to Warwick. It was stuck away in rack in the back of a shed which was hard to get to. On first appearance I thought it was a Chapman Pup as it had the rounded barrel general styling like a Pup but it had the bread loaf magneto stuck out the end of the crankshaft on the opposite side to the flywheel. It was red and it looked original paint. I could not turn the engine around to see details from the off side. All I could see was the magneto (on left) barrel with carbi with fuel bowl and then flywheel on the right). I could feel that it was not seized. It was small. I reckon I could lift it off the shelf into the back of the old Pajero if push came to shove.
I couldn't see any tags but there's nothing to say there are no tags on the side I could not see.
Anyone have any guesses as to what it is?
Hello all.
I went back today and I discovered something. I discovered I'm an idiot....plain and simple. I seem to turn into a little kid looking in a window full of lollies where looking at engines is concerned, especially where lots of engines are sitting around staring at me all saying....take me you dumb @r$e. As I keep saying.....kid in a lolly shop.
So this is what I asked you good people about. A red single cylinder 2 stroke marine engine with magneto out the end of the crankshaft.
Would you believe that when I got back the engine had turned into a green 4 stroke engine (that may not be marine) with the magneto out the side? Idiot!!!!!
At least I got a few things right. It was a single cylinder engine with no tag and a magneto. Idiot!!!!
So here is what I got. Any ideas?
It has some interesting features like no dip stick that I could find (probably is one, just not seen it seeing I'm an idiot) and the timing gears.
The magneto mount appears to be home made. But again....I'm an idiot so it could be anything.
It seems to be in great nick inside and I think I found something which would cause a bit of a concern. The valve timing is out by a tooth (you can possibly see the timing marks in the last picture).
Cheers Scott (the idiot!!!!!)
The Following User Says Thank You to Scotty 2 For This Post:
Old 01-20-2019, 02:17:39 AM
Back again.
I also saw this there. A 2 cylinder diesel marine engine I think .
Any guesses?
Cheers Scott
Old 01-20-2019, 05:53:02 AM
vs ss vs ss is offline
Don’t worry Scotty, as the saying goes “shit happens”. Im pretty certain a lot of us have got overwhelmed in a situation like that before. I can’t help you out on make but it’s a nice little score, looks like a technico Maggie?
Cheers, mike.
Old 01-20-2019, 08:22:21 PM
Cheers, mike.
Yep. Sure is. And it's a good one. Coil is OK. Good eye there young fella.
I had a bit of a think about it last night and something else dawned on me. There's no governor.
Cheers Scott
Old 01-20-2019, 09:32:41 PM
Chester Chester is offline
[QUOTE=Scotty 2;1546490]Hello all.
Plix copy?, maybe a Mathews?,
The Following User Says Thank You to Chester For This Post:
Old 01-20-2019, 09:36:51 PM
Nathan Woodruff Nathan Woodruff is offline
I could be wrong but your little engine Scott looks a lot like one a mate has that is direct coupled to a generator and uses the generator output to electronically govern the engine. I could be wrong but just a thought. I can't remember the make of my mates.
The Following User Says Thank You to Nathan Woodruff For This Post:
single cylinder Buda diesel marine engine R. Kern Antique Marine Engines and Outboard Motors 0 07-23-2017 11:00:41 AM
single cylinder 2-cycle Grey Marine engine Craig DeShong Antique Marine Engines and Outboard Motors 12 04-01-2014 05:59:44 PM
Marine single cylinder Ted_Cool Onan Generators 4 03-12-2010 11:23:05 PM
Unknown Single Cylinder Marine Engine Andrew Walker Antique Marine Engines and Outboard Motors 0 02-24-2009 01:55:10 PM
Single cylinder four stroke valve setting Gene Fisher Antique Gas Engine Discussion 3 01-08-2007 08:07:54 PM
