Smokstak Down Under
Keighley/Pitt Oil Engine
this thread has 10 replies and has been viewed 3020 times
Old 04-05-2011, 05:30:25 PM
waynocp waynocp is offline
Default Keighley/Pitt Oil Engine
i am looking for parts for a 7 hp keighley oil engine missing hot bulb vaporizer and fuel pump etc any help or info thanks?
wayne
ID:	104080   Click image for larger version
Old 04-06-2011, 03:31:07 AM
Lanzb Lanzb is offline
Default Re: Keighley/Pitt Oil Engine
You can make it go no worries without all of that stuff on it.
The Following User Says Thank You to Lanzb For This Post:
Old 04-06-2011, 03:43:47 AM
thanks for your reply was the engine in the picture a hot bulb?
---------- Post added at 05:43 PM ---------- Previous post was at 05:38 PM ----------
do you have any part to copy hot bulb etc Lanzb
Old 04-06-2011, 04:29:48 AM
Yes it was a hot bulb engine but thats long gone, It was converted back before the 50's to run on petrol. I don't see any need to change it back as it runns great like it is. You can see the cast pipe and cap in the place of the hot bulb with the spark plug in the end. It had a hot box thing on it but I found the petrol was pooling in the bottom of it so I took in off, It was put on with the conversion it had.
---------- Post added at 06:29 PM ---------- Previous post was at 06:20 PM ----------
Here is a pic of what it looked like before I started
Old 04-06-2011, 04:38:55 AM
Thanks Lanzb for your info,my engine at the back just under bearings has four bolts on each side of the crank case with a thread in each plate.No oilers on the top of the bearing cap just little plugs and one oiler for the big end.is your engine the same?
Old 04-06-2011, 04:44:16 AM
here is a pic you must have sent me of your engine and here is a picture of a keighley imperial pitt 4 1/2 hp
ID:	104127   Click image for larger version
Old 04-06-2011, 04:58:57 AM
Yes I did email you about yours a while ago. Mine doesnt have those plates at the back but it's also a smaller engine and a Pitt not Keisley
---------- Post added at 06:58 PM ---------- Previous post was at 06:56 PM ----------
Mine should also have a wiper type thing to oil the big end but I don't have that neither, I just have a small oil cup on the big end bearing like a blackstone.
Old 04-06-2011, 05:10:15 AM
OK thanks Lanzb i have got a few more parts for my engine since we emailed fuel sprayer governor just need to machine fuel pump big end and get a few other bits.hope someone out here can help!
Old 04-06-2011, 08:09:09 AM
Wayne Timms Wayne Timms is offline
Hi Wayne,
About 2 years ago a collector in Murray Bridge in SA was selling some engines, one of which was a hot-bulb Pitt. I have sent you a private message with his details.
Regards,
Wayne
www.bluefuel-whitesmoke.com
The Following User Says Thank You to Wayne Timms For This Post:
Old 04-11-2011, 03:48:22 AM
junction 28 junction 28 is offline
hi there is a small keighly pitt engine on stationary engine ebay uk with some detaied photographs of it on at the moment worth a look. for ideas
junction 28
The Following User Says Thank You to junction 28 For This Post:
Old 04-11-2011, 05:51:48 AM
Thanks junction 28 for the info but engine is different and is full base thanks
wayne
Is the Wheeling Pitt Corliss a Mesta? Rick Rowlands Steam Stationary Engines, Traction Engines 4 11-22-2009 07:31:55 PM
Invincible Engine Co. - Keighley, England Pix dusty Antique Engine Archives 0 09-29-2004 12:23:58 PM
Pitt Engineering Co. Pix Patrick M Livingstone Antique Engine Archives 0 07-21-2003 10:12:33 AM
Pitt Engineering Co. Pix Patrick M Livingstone Antique Engine Archives 0 07-21-2003 10:05:46 AM
pitt engine information Bob Turner Antique Engine Archives 0 11-22-2001 10:55:54 PM
