Delco Model 7562 Fan
this thread has 15 replies and has been viewed 1307 times
Old 10-09-2017, 11:38:33 AM
Default Re: Delco model 7562 fan
OK you guys have my interest up! I recently picked up a delco Electrifier. ( look for my post under Delco , low voltage generators) Here are pictures of the info I got with it. Note in the add it states no A battery , But doesn't say that you may need a B battery , therefore the Electrifier. I'll do some more research when I get time. I've collected radio for a long time and go to the Kutztown shows. The radios shown are Delco RA3 , RB3. Ron
ID:	293188   Click image for larger version
ID:	293189   Click image for larger version
ID:	293190   Click image for larger version
The Following 2 Users Say Thank You to Ronald E. McClellan For This Post:
Old 10-10-2017, 05:49:02 PM
Mike Schweikert's Avatar
Mike Schweikert Mike Schweikert is offline
Images: 26
Default Re: Delco Model 7562 Fan
I think that electrifier designed to take 32v in and step up and down to get B+ and filament voltages for standard battery receivers right?.
Would make sense as then you could run any set off of the light plant. I've seen them over the years, but never owned one.
Mike Schweikert
Jamison PA
See my videos at: http://www.youtube.com/user/standardtwin1
Old 10-11-2017, 10:54:57 AM
I did some research last night on the model numbers that I have. Delco radios are listed under Delco radios , Delco appliances . United Motors. Delco RA3 & RB3 , 32 V for filament & pilot light , B battery 140 V & 68 V , The Electrifier replaces the B battery.****Mod. 3201 & 3202 & 3205 32 V filament & plate work on 32 V ****, 4049 & 4051 32 V with vibrator ,****3203 & 3204 32 V or 6 V (not sure) vibrator**** Crosley 159 32 V B supply from a Crosley Syncronode , (vibrator)****Sears Silvertone 1863 32 V filament & plate are 32 V.**** That makes four ways the 32 V radios were powered. B battery , vibrator , all 32 V , & Electrifier. Ron
Old 10-11-2017, 01:21:15 PM
Images: 26
I think it was the same idea as the radios that had the built in pioneer gen-e motor, that worked the same way, stepping up incoming battery DC for B+. I cannot remember which Radio I saw that on, but it was a tombstone set. The difference here is a separate cabinet and transformer to accomplish the same idea.
They are neat and make a very cool display
Mike Schweikert
Jamison PA
Old 10-18-2017, 09:47:44 PM
Dale Burkman Dale Burkman is offline
Sentinel and Sears (Silvertone) built a set that used a Pioneer Gen-E-Motor {dynamotor} for their B+. I'm sure there was other sets that used them. The dynamotor power supplies was earlier than the vibrator power supplies.
Old 10-19-2017, 02:31:39 PM
Before the vibrator power supplies there were auto radios that used motor generators for B supply. 32 Ford was one. I had a couple of these , one Ford and one other , I don't know the name. Ron
Delco light model 600 need help Jon4ford Delco and other Low Voltage DC Light Plants 1 06-25-2017 08:42:22 AM
Delco Model 8C3 bsaeland Generators & Electric Motors General Discussion 0 09-28-2016 09:51:35 AM
Delco model 600 Steve Wright Generators & Electric Motors General Discussion 3 08-19-2002 03:47:08 PM
Delco Model 8C3 Bob Kelly Delco and other Low Voltage DC Light Plants 1 01-30-2001 07:09:38 PM
Delco Model B6 Bill Chason Generators & Electric Motors General Discussion 0 11-14-2000 09:55:51 PM
