Delco light model 600 need help
this thread has 1 replies and has been viewed 777 times
Old 05-23-2017, 01:02:22 PM
Jon4ford Jon4ford is offline
Default Delco light model 600 need help
Hello all, I am a new owner of a delco light 600. I am in need of a wiring diagram for the panel. I would greatly appreciate any info or pictures of the wiring. According to the serial number and research, it is a 1926 model. The panel has the starting switch, a Weston 30-0-30 ammeter, and a 40 amp fuse. It does not have the original ignition cool, and was curious if I could use a standard automotive ballast resistor to bring the voltage down to the standard automotive coil. Again any info would be greatly appreciated, I am new to the Delco light plants and would love to get this unit back working correctly. Thanks.
Old 06-25-2017, 08:42:22 AM
FDChief FDChief is offline
Default Re: Delco light model 600 need help
I have reprint manuals for sale, send me a picture of it to make sure I get you the right one
Fdchief@aol.com
Jeff Himelick
Delco Model 752 and 8C3 light plants ZachB Delco and other Low Voltage DC Light Plants 7 10-23-2015 12:11:14 PM
Delco Light model 9004 netpirate8 Delco and other Low Voltage DC Light Plants 3 09-06-2014 10:36:18 PM
Delco Light 8-C-3 (model 752) bigGURN Delco and other Low Voltage DC Light Plants 8 04-21-2013 04:20:35 PM
Delco Light Plant Model 850 curt andree Delco and other Low Voltage DC Light Plants 2 09-25-2010 04:17:55 PM
Delco-Light model 600 Bruce Bailey Delco and other Low Voltage DC Light Plants 4 01-24-2007 06:22:34 PM
