Fairbanks Morse ZC-52 Light Plant
this thread has 8 replies and has been viewed 1237 times
Old 01-14-2019, 11:12:37 AM
forney00c forney00c is offline
Default Fairbanks Morse ZC-52 Light Plant
I recently bought a Fairbanks Morse ZC-52 engine that came with a generator setup with a condenser that mounts to the hopper. I've seen a video of one, but don't see much else on them as most of the generators I've found from research mount to and extended sub base along with the engine. I'd like to see if anyone has any literature on the hopper mounted setup.
This is my first antique generator/light plant and I could use a little guidance on where to start with working on the generator head and what things to check. I don't have any worries about the engine as it is complete and appears to be in relatively good shape. If anyone has information they could pass along about this style of generator, I would really appreciate it. Thanks!
ID:	326307   Click image for larger version
The Following 2 Users Say Thank You to forney00c For This Post:
Old 02-11-2019, 03:03:11 AM
Jeff Taylor Jeff Taylor is offline
Default Re: Fairbanks Morse ZC-52 Light Plant
This is the Fairbanks Model A light plant 1500 watt version. They also made a 750 watt based on the ZD. The engine is still a 3hp Z style C. The ZC-52 is a 1941 designation.
The 3hp ZC came out in 1928 with the Fairbanks type R mag, which yours has. RV and J mags came later. What is the serial number on the back of the hopper?
The pictures I have attached are from a sales brochure that I have. Top left corner says oct 1. 1929, 3rd page is what you have.. Sorry I don't have more.
Hit N miss ent has a bunch of parts for these engines. As long as the pot metal gear bracket is not cracked you should be ok. As for the gen, spin it and see if it makes any power. It probably has ball bearings that need little attention. Check the bushes and see how clean the commutator is. Commutator can be cleaned up with some 320-400 git sand paper.
ID:	328398   Click image for larger version
ID:	328399   Click image for larger version
ID:	328400   Click image for larger version
ID:	328401   Click image for larger version
ID:	328403   Click image for larger version
Old 04-01-2019, 12:17:33 PM
Thanks for the brochure pictures, Jeff! I can't make out what the serial number is as it is very hard to read. Maybe I could make it out if I sanded the boss. I have found a wiring diagram that I believe to be correct for this light plant, but I appear to be missing a fuse and fuse holder inside the control box. Any idea how many amps the fuse would be rated at?
Old 04-01-2019, 03:53:48 PM
Exclamation Re: Fairbanks Morse ZC-52 Light Plant
I had a F/M 3 home lite plant - 3 HP special electric ZA type engine.(open crankcase), rated at 425RPM 32 VDC. The 'radiator' was mounted on the engine hopper. it was actualy a condenser. My light plant had a 40 amp cartridge fuse - about 1/2" OD by about 21/2" long
Old 04-01-2019, 06:51:49 PM
I would caution against sand paper or any other grit based material for cleaning commutators and collector rings. The grrit dislodges, becomes embedded in the soft copper, then eats up the brushes. Instead, Scotchbrite pads are perfect for this.
I would also keep sand paper away from the stamped numbers and *especially* nameplates! I have seen more ruined this way than I can count. Instead use a light oil such as P'blaster and a rag and maybe a soft tooth brush.
Old 05-24-2019, 07:20:25 AM
Thank you for the replies, Andrew and Vanman. I'll keep the scotchbrite pads in mind for the commutator. Now that it is warmer, maybe I'll have a chance to pull the unit out, hook up a couple batteries and see if it will spin over when I push the start button. I have a feeling the engine will be a decent sized project in itself as about the only things it has going for it are the facts that it is complete and loose. Other than that, no compression, no spark and something rattles inside when I turn it over.
Old 05-24-2019, 08:01:33 AM
Could you post pics of the generator? I don’t see it in the bed of your truck. I’ve never worked on a ZC, I’ve got an older 3hp Z open crankcase. It’s been a while since I worked on it and I’m not sure it’s all that similar design, but my problem was the camshaft had come out of time when the key on the crankshaft vibrated out. No compression is probably just crud under the valves.
Old 05-24-2019, 10:18:28 AM
Angry Sailor, I can take a couple more pictures today after work. In the pictures above, the generator is between the ZC and the LB. You can mostly see the control panel and condenser, the generator itself is close to the LB.
The Following User Says Thank You to forney00c For This Post:
Old 06-13-2019, 09:30:48 PM
Here are some pictures of the engine and generator together in the garage.
ID:	337107   Click image for larger version
ID:	337108   Click image for larger version
ID:	337109   Click image for larger version
Fairbanks Morse Light Plant Dan Zumstein Generators & Electric Motors General Discussion 4 07-22-2016 05:12:20 PM
fairbanks morse light plant Geist Antique Gas Engine Discussion 3 04-14-2014 07:54:02 PM
Fairbanks Morse light plant Geist Antique Gas Engine Discussion 13 02-20-2014 09:45:44 PM
Fairbanks,Morse light plant Clint Querry Generators & Electric Motors General Discussion 1 01-22-2004 11:42:30 PM
Fairbanks morse light plant Frank Y Generators & Electric Motors General Discussion 1 10-23-2002 01:00:26 PM
