Where can I get Parts for a Boliy?
this thread has 12 replies and has been viewed 5479 times
Old 12-23-2015, 02:10:42 PM
Default Where can I get Parts for a Boliy?
Last month I picked up a Boliy Pro3600SiE generator for $75 on Craig's List.
It was totally neglected but after a good cleaning and a few small repairs it runs and generates perfectly.
Starts easy using the electric start or recoil and is much lighter than comparable units. The inverter is built in Germany and the unit is built by a Chinese mold company. The packaging is impressive and fairly well thought out.
At the price it's a fantastic generator and I'm very pleased. But most reviews mention parts availability.
Overall it's a pretty nice unit but like everything it's no better than the service and parts availability.
Anyone know where to get parts? I emailed two sellers I found but no response yet.
ID:	242058   Click image for larger version
Old 12-25-2015, 09:50:12 PM
Jerry Christiansen Jerry Christiansen is offline
Default Re: Where can I get parts for a Boliy?
Hi Joe,
I see that about 120 other people looked at this thread. I have a Boliy generator similar to yours, mine is blue.
I am bumping this with the hope that someone knows where to get parts.
Mine has worked very well for us. It doesn't need any repairs, but knowing where to get parts can be a comfort.
Later,
Jerry Christiansen
The Following User Says Thank You to Jerry Christiansen For This Post:
Old 12-25-2015, 11:01:39 PM
PLCtech PLCtech is offline
That engine resembles the one on a Cub Cadet garden tiller I use.
Old 12-26-2015, 09:20:28 AM
Jerry.
Mine is an older one bought in 2010 I paid $75 for it and the yearly maintenance schedule tells you to check the cooling fan
So I removed the end cover, muffler end, 4 screws for the fan cover and found my fan loose on the end of the engine crank shaft
The ads for Boliey units seem to say things like latest model or all the improvements or whatever. I would hope they improved the mounting of the cooling fan on your unit.
The thickness of the plastic fan where it bolts to the extension of the crank shaft is about 1/8" thick and the wears badly expeciallt the"flat" key. You can see I put a larger washer I machined down to just fit the inside of the hub. The fan it tight now but I would like to replace it. I found the fan loose on the shaft but the bolt had thread locker on it and was tight. If I can't get one I'll add an extension to the steel extension on the crankshaft and mount the fan using the three holes.
The pictures show the front side of the fan but when you remove the cover you see the back side of the fan.
Joe
ID:	242269   Click image for larger version
Old 09-06-2016, 05:06:43 PM
Ok I got an extra "round tuit" and made a substantial mount for the cooling fan yesterday.
The fan runs true and should not cause any problems in the future.
Joe
Old 09-06-2016, 06:41:48 PM
Jim Rankin Jim Rankin is offline
Very nice repair
Old 03-19-2018, 09:28:26 PM
Tim Venetis Tim Venetis is offline
Originally Posted by Jim Rankin View Post
Very nice repair
Hi this place in California sells parts phone number is 858-689-8899 or bottom line trading in texas has parts his name is Tom number is 512 3397.
Old 03-20-2018, 12:24:47 AM
Since the thread got resurected from 12-2015, I will add another Chinese gen parts supplier. I was trying to locate an ignition module for a Xingyou inverter gen.... they at least took the time to look and answer my emails. https://www.generatorguru.com
Doc
" When in doubt, tell the truth" - Mark Twain
Old 03-20-2018, 12:45:56 AM
Missing 3 digits in that Tx phone number, must be somewhere close to me, but never heard of them. Correct phone# (512)902-3397, website http://www.bottomlinetrading.com/ but no info on where they are
Old 03-20-2018, 07:25:08 AM
Default Re: Where can I get Parts for a Boliy?
Sorry forgot 3 numbers it is 512 902 3397
Old 06-04-2019, 03:57:27 PM
Hi all,
Yes, we are reviving an old thread. I am in need of a couple covers for my Boliy. I have contacted the places listed above, they are getting away from the Boliy line and only have a few parts available.
Any new leads on part sources? Are Boliys still being made? Does anyone have a non-runner they are willing sell some parts from ?
Thanks,
Jerry Christiansen
Old 06-04-2019, 04:31:13 PM
Originally Posted by Jerry Christiansen View Post
Hi all,
Thanks,
Jerry Christiansen
I have 2 boliy I fixed up for sale and they run well. I wonder why there are getting away from them?s
Old 06-06-2019, 08:46:23 AM
It's an old design and has been around a while.
I'm sure whoever made them is still alive making generators with another name.
Besides their mail order send you the parts to put on warranty is a hassle for those not able to replace them. The one I bought came with a new carburetor, regulator harness and recoil assy. But the seller could not find anyone local who wanted to replace them. It had sat for a couple of years in a damp garage and was a filthy moldy mess. I striiped it down to nothing, gave it a good cleaning, color coded all the connections using colored cable ties and a new battery. After that I read they recommended checking the blower yearly. What a flimsy arrangement that was. See my fix above.
Other then the weight I like it better then my Honda Eu2001 because it's quieter watt for watt.
Boliy Inverter Question Tim Venetis Generac Generators (SEARS, etc.) 3 03-28-2018 04:49:17 AM
12-20 Twin City Cylinder Head Parts interchangeable to new available parts. jesters13 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 05-31-2017 11:37:59 PM
Clinton Master Parts Price list (1964) & parts cross-reference TractorDom Small Air Cooled Gasoline Engines 0 11-26-2015 11:02:54 PM
Digitize 3D Parts, Broken parts, etc. Great video shown at Jay Leno's Garage Dusty Antique Gas Engine Discussion 0 04-10-2013 11:19:56 AM
Looking for Goold shapley and muir 3 1/2HP parts and to contact others needing parts Nathan K. Antique Gas Engine Discussion 8 03-16-2013 11:52:47 PM
